[pgrouting-users] assign_vertex_id error
Annu Anurag
i.skidoosh at gmail.com
Tue Jun 12 08:20:03 PDT 2012
You were right sir. The entries were actually null entries. I had not
assigned any length and other parameters to them. They were just names.
Anyways, I deleted them. The query still hasn't run. The same error is
being thrown back.
VSDelhidb=# select * from roads_line where the_geom is NULL;
VSDelhidb=# delete from roads_line where the_geom is Null;
DELETE 11
VSDelhidb=# SELECT assign_vertex_id('roads_line', 0.0002, 'the_geom',
'gid');
NOTICE: CREATE TABLE will create implicit sequence "vertices_tmp_id_seq"
for serial column "vertices_tmp.id"
CONTEXT: SQL statement "CREATE TABLE vertices_tmp (id serial)"
PL/pgSQL function "assign_vertex_id" line 15 at EXECUTE statement
ERROR: new row for relation "vertices_tmp" violates check constraint
"enforce_srid_the_geom"
CONTEXT: SQL statement "INSERT INTO vertices_tmp(the_geom) VALUES
(SetSRID(p,_srid))"
PL/pgSQL function "point_to_id" line 26 at SQL statement
PL/pgSQL function "assign_vertex_id" line 33 at assignment
I'm new to postgis and postgresql. Most of the details don't make very much
sense to me. But I just need to get the routing function running. I'm
trying my best to find a solution from all the posts I can find but you
know the functioning of pgrouting, please try and help me solve this
problem. Thank you!
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120612/215e4278/attachment-0001.html>
More information about the Pgrouting-users
