[pgrouting-users] shortest path query
Annu Anurag
i.skidoosh at gmail.com
Tue Jun 12 19:10:32 PDT 2012
Dear sir, I tried the following query. It seems right to me. But mapserver
is throwing up an error:
msDrawMap(): Image handling error. Failed to draw layer named 'route'.
msPostGISLayerWhichShapes(): Query error. Error executing query: ERROR:
column reference "the_geom" is ambiguous LINE 1: select
encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR'),'he... ^
It says, "column reference "the_geom" is ambiguous"
The query I used is this:
DATA "the_geom FROM (SELECT b.the_geom, b.* FROM (SELECT * FROM
shortest_path('SELECT gid AS id, fromnodeid::int4 AS source, tonodeid::int4
AS target, length0::float8 AS cost FROM edges_line', 35, 210, false,
false)) AS a, edges_line AS b WHERE a.edge_id = b.gid) AS foo using unique
gid using srid=4326"
I'm searching for some explanation on the internet too. What could be wrong
here?
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120613/3c8e14fa/attachment.html>
More information about the Pgrouting-users
