[pgrouting-users] shortest path query
Annu Anurag i.skidoosh at gmail.com
Tue Jun 12 19:25:28 PDT 2012
Is there a problem with the 'b.geom' reference in SELECT b.the_geom, b.*
.... ?? There isn't a 'the_geom' column in 'edges_line' as such..
DATA "the_geom FROM (SELECT b.the_geom, b.* FROM (SELECT * FROM
shortest_path('SELECT gid AS id, fromnodeid::int4 AS source, tonodeid::int4
AS target, length0::float8 AS cost FROM edges_line', 35, 210, false,
false)) AS a, edges_line AS b WHERE a.edge_id = b.gid) AS foo using unique
gid using srid=4326"
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120613/fe50c87a/attachment.html>
More information about the Pgrouting-users mailing list
