[pgrouting-users] Reduce the graph
Stephen Woodbridge woodbri at swoodbridge.com
Fri Mar 9 11:48:33 EST 2012
On 3/9/2012 11:39 AM, Aurélien FILEZ wrote:
> Hi all,
> My edge table has some useless nodes. For example :
> edge_id    v1      v2      the_geom
> 1              1        2      LINESTRING(x1 y1, x2 y2)
> 2              2        3      LINESTRING(x2 y2, x3 y3)
> But the vertex 2 is no used in any other edge.
> So I would like reduce my graph to transforme this previous example to :
> 1              1        3      LINESTRING(x1 y1, x2 y2, x3 y3)
> Is there is a way to do that ?
> Thank you all :)
There is no automatic way to do this. I have done a lot of graph
analysis by adding a cnt column to the vertices_tmp column and then
updating it to the count of edges connected to that vertex.
Then you can do things like look for:
deadends - cnt=1
connected lines - cnt=2
You could write a stored procedure to that the connected lines, join
them together, and update the relevant tables to reflect the new topology.
-Steve
More information about the Pgrouting-users mailing list
