[pgrouting-users] Reduce the graph
Aurélien FILEZ
kinju59 at gmail.com
Sat Mar 10 02:20:08 EST 2012
This table is build with lines I decompose in segments of 2 points.
Maybe it is better to act from these full lines, searching points used by
more than one line ?
Thanks,
Kin
On Fri, Mar 9, 2012 at 5:48 PM, Stephen Woodbridge
<woodbri at swoodbridge.com>wrote:
> On 3/9/2012 11:39 AM, Aurélien FILEZ wrote:
>> Hi all,
>> My edge table has some useless nodes. For example :
>> edge_id v1 v2 the_geom
>> 1 1 2 LINESTRING(x1 y1, x2 y2)
>> 2 2 3 LINESTRING(x2 y2, x3 y3)
>> But the vertex 2 is no used in any other edge.
>> So I would like reduce my graph to transforme this previous example to :
>> 1 1 3 LINESTRING(x1 y1, x2 y2, x3 y3)
>> Is there is a way to do that ?
>> Thank you all :)
> There is no automatic way to do this. I have done a lot of graph analysis
> by adding a cnt column to the vertices_tmp column and then updating it to
> the count of edges connected to that vertex.
> Then you can do things like look for:
> deadends - cnt=1
> connected lines - cnt=2
> You could write a stored procedure to that the connected lines, join them
> together, and update the relevant tables to reflect the new topology.
> -Steve
> ______________________________**_________________
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120310/865c116b/attachment.html
More information about the Pgrouting-users
