[pgrouting-users] pgrouting win7 postgreSQL 9.1 installation
problem!!!
Jorge Fuentes
jfuentes at estudiantes.uci.cu
Tue May 1 14:24:27 EDT 2012
Hi i just read the message below, and i understood that there is not importance about what version of
PostgreSQL you were running you could use those binaries.. but i try with 9.1 and i get an error
saying that i should use Postgres 8.4 then i don't understand..(when i try to run .sql files in
/share/contrib/ folder)
I will appreciate any help
Hi James,
I am sorry to a late reply your mail because I become busy with my writing
PhD Journal Paper.
About this page:http://www.pgrouting.org/docs/howto/build_on_windows.html
you don't need to follow.
You can follow this steps;
Unzip a ZIP file which you have downloaded ( "pgRouting-1.03_pg-8.4.2 ").
after you are unzip you will get 3 folders (Doc, Lib, and Share) and if you
go to
"C:\Program Files (x86)\PostgreSQL\9.0" then you should see the same name
folder as the folder when you unzip from pgRouting-1.03_pg-8.4.2.zip.
"C:\Program Files (x86)\PostgreSQL\9.0\Doc"
"C:\Program Files (x86)\PostgreSQL\9.0\lib"
"C:\Program Files (x86)\PostgreSQL\9.0\Share"
Then, copy all the data in the folder when you unzip from
pgRouting-1.03_pg-8.4.2.zip. and paste into the same folder name in
"C:\Program Files (x86)\PostgreSQL\9.0\...."
For example;
in "C:\Users\sittichai\Downloads\pgRouting-1.03_pg-8.4.2\Lib" folder, copy
all 3 files (librouting.dll, libroutind_dd.dll, librouting_tsp.dll) and
paste into "C:\Program Files (x86)\PostgreSQL\9.0\lib"
Please feel free to contract this mailing list if you have any questions.
Sittichai
10mo. ANIVERSARIO DE LA CREACION DE LA UNIVERSIDAD DE LAS CIENCIAS INFORMATICAS...
CONECTADOS AL FUTURO, CONECTADOS A LA REVOLUCION
http://www.uci.cu
http://www.facebook.com/universidad.uci
http://www.flickr.com/photos/universidad_uci
More information about the Pgrouting-users
