[pgrouting-users] pgrouting win7 postgreSQL 9.1 installation
problem!!!
Daniel Kastl
daniel at georepublic.de
Tue May 1 23:05:40 EDT 2012
Hi Jorge,
No, I think it matters which version of PostgreSQL/PostGIS the Windows
binaries were built.
You can find binaries in the GitHub repository of Sanak:
https://github.com/sanak/pgrouting/downloads
Daniel
On Wed, May 2, 2012 at 3:24 AM, Jorge Fuentes
<jfuentes at estudiantes.uci.cu>wrote:
> Hi i just read the message below, and i understood that there is not
> importance about what version of
> PostgreSQL you were running you could use those binaries.. but i try with
> 9.1 and i get an error
> saying that i should use Postgres 8.4 then i don't understand..(when i try
> to run .sql files in
> /share/contrib/ folder)
> I will appreciate any help
> Hi James,
> I am sorry to a late reply your mail because I become busy with my writing
> PhD Journal Paper.
> About this page:http://www.pgrouting.org/**docs/howto/build_on_windows.**
> html <http://www.pgrouting.org/docs/howto/build_on_windows.html>
> you don't need to follow.
> You can follow this steps;
> Unzip a ZIP file which you have downloaded ( "pgRouting-1.03_pg-8.4.2 ").
> after you are unzip you will get 3 folders (Doc, Lib, and Share) and if you
> go to
> "C:\Program Files (x86)\PostgreSQL\9.0" then you should see the same name
> folder as the folder when you unzip from pgRouting-1.03_pg-8.4.2.zip.
> "C:\Program Files (x86)\PostgreSQL\9.0\Doc"
> "C:\Program Files (x86)\PostgreSQL\9.0\lib"
> "C:\Program Files (x86)\PostgreSQL\9.0\Share"
> Then, copy all the data in the folder when you unzip from
> pgRouting-1.03_pg-8.4.2.zip. and paste into the same folder name in
> "C:\Program Files (x86)\PostgreSQL\9.0\...."
> For example;
> in "C:\Users\sittichai\Downloads\**pgRouting-1.03_pg-8.4.2\Lib" folder,
> copy
> all 3 files (librouting.dll, libroutind_dd.dll, librouting_tsp.dll) and
> paste into "C:\Program Files (x86)\PostgreSQL\9.0\lib"
> Please feel free to contract this mailing list if you have any questions.
> Sittichai
> 10mo. ANIVERSARIO DE LA CREACION DE LA UNIVERSIDAD DE LAS CIENCIAS
> INFORMATICAS...
> CONECTADOS AL FUTURO, CONECTADOS A LA REVOLUCION
> http://www.uci.cu
> http://www.facebook.com/**universidad.uci<http://www.facebook.com/universidad.uci>
> http://www.flickr.com/photos/**universidad_uci<http://www.flickr.com/photos/universidad_uci>
> ______________________________**_________________
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120502/c0cd4bea/attachment.html
More information about the Pgrouting-users
