[pgrouting-users] postgis 2.0 and postgresql 9.1
James David Smith
james.david.smith at gmail.com
Wed May 23 06:18:50 EDT 2012
Hi Pedro,
Would be very grateful if you'd provide a short summary of what you
did to get it all working - along with links to the download packages?
Thanks
James
On 23 May 2012 11:13, Pedro Costa <pedrocostaarma at sapo.pt> wrote:
> Perfect....works....
> Thanks
> Em 22-05-2012 23:42, Sanak escreveu:
> Hi Pedro,
> If you use pgRouting on Windows, download module from
> here(https://github.com/sanak/pgrouting/downloads -
> pgRouting-git-sanak-mingw_20120310_pg-9.1(x86).zip).
> Because above module was based on git master
> branch(https://github.com/pgRouting/pgrouting) after justjkk's latest
> commit(2011/08/08), some drnextgis's sql fixes had already applied after
> release 1.0.5,
> but more drnextgis's fix(https://github.com/pgRouting/pgrouting/pull/50) may
> be necessary.
> Hi Jorge,
> Thanks for your report about PostgreSQL version incompatibility.
> I will check about this problem.
> Sorry for my english.
> Regards,
> 2012/5/23 Jorge Fuentes <jfuentes at estudiantes.uci.cu>
>> Was just easy like double clik and next next...
>> but a had to download binaries from (I don't remember)
>> .. but I'm sure that you will find that url in older post or googlering
>> it..
>> and be sure that you had postgreSQL 9.1.3 32 bit because i try with 9.1.1
>> and not work because a dll change from that version to 9.1.3
>> remember to execute .slq file from pgrouting
>> best regards
>> El 22/05/2012 12:35 pm, Pedro Costa escribió:
>>> Em 22-05-2012 16:48, Jorge Fuentes escreveu:
>>>> Yes I had them install and running PosgreSQL 9.1.3, postGIS 2.0 and
>>>> pgrouting on win 7-32bits
>>> Hi Jorge,
>>> It was necessary to any change in code? Or were the normal procedures?
>>> Thanks
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>> 10mo. ANIVERSARIO DE LA CREACION DE LA UNIVERSIDAD DE LAS CIENCIAS
>>> INFORMATICAS...
>>> CONECTADOS AL FUTURO, CONECTADOS A LA REVOLUCION
>>> http://www.uci.cu
>>> http://www.facebook.com/universidad.uci
>>> http://www.flickr.com/photos/universidad_uci
>> INFORMATICAS...
>> http://www.uci.cu
More information about the Pgrouting-users
