[pgrouting-users] postgis 2.0 and postgresql 9.1
Pedro Costa pedrocostaarma at sapo.pt
Wed May 23 06:13:54 EDT 2012
Perfect....works....
Thanks
Em 22-05-2012 23:42, Sanak escreveu:
> Hi Pedro,
> If you use pgRouting on Windows, download module from
> here(https://github.com/sanak/pgrouting/downloads -
> pgRouting-git-sanak-mingw_20120310_pg-9.1(x86).zip).
> Because above module was based on git master
> branch(https://github.com/pgRouting/pgrouting) after justjkk's latest
> commit(2011/08/08), some drnextgis's sql fixes had already applied
> after release 1.0.5,
> but more drnextgis's
> fix(https://github.com/pgRouting/pgrouting/pull/50) may be necessary.
> Hi Jorge,
> Thanks for your report about PostgreSQL version incompatibility.
> I will check about this problem.
> Sorry for my english.
> Regards,
> 2012/5/23 Jorge Fuentes <jfuentes at estudiantes.uci.cu
> <mailto:jfuentes at estudiantes.uci.cu>>
>     Was just easy like double clik and next next...
>     but a had to download binaries from (I don't remember)
>     .. but I'm sure that you will find that url in older post or
>     googlering it..
>     and be sure that you had postgreSQL 9.1.3 32 bit because i try
>     with 9.1.1 and not work because a dll change from that version to
>     9.1.3
>     remember to execute .slq file from pgrouting
>     best regards
>     El 22/05/2012 12:35 pm, Pedro Costa escribió:
>         Em 22-05-2012 16:48, Jorge Fuentes escreveu:
>             Yes I had them install and running PosgreSQL 9.1.3,
>             postGIS 2.0 and pgrouting on win 7-32bits
>         Hi Jorge,
>         It was necessary to any change in code? Or were the normal
>         procedures?
>         Thanks
>         _______________________________________________
>         Pgrouting-users mailing list
>         Pgrouting-users at lists.osgeo.org
>         <mailto:Pgrouting-users at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>         10mo. ANIVERSARIO DE LA CREACION DE LA UNIVERSIDAD DE LAS
>         CIENCIAS INFORMATICAS...
>         CONECTADOS AL FUTURO, CONECTADOS A LA REVOLUCION
>         http://www.uci.cu
>         http://www.facebook.com/universidad.uci
>         http://www.flickr.com/photos/universidad_uci
>     10mo. ANIVERSARIO DE LA CREACION DE LA UNIVERSIDAD DE LAS CIENCIAS
>     INFORMATICAS...
>     http://www.uci.cu
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120523/f97d6b6c/attachment.html
More information about the Pgrouting-users mailing list
