[pgrouting-users] FW: Multiple queries in a row
Daniel Kastl daniel at georepublic.de
Wed Nov 21 05:40:28 PST 2012
On Wed, Nov 21, 2012 at 10:15 PM, Iñigo Vázquez <ivgwildchild666 at hotmail.com
> wrote:
> Nice! I think this should be valid for my case. But I'm having some
> troubles in compilation/installation.
> I've downloaded the .zip archive from github and I extracted it. From
> "cmake" folder I execute this command "cmake -DWITH_DD=ON" and then, when
> I try to execute this one "sudo make install"  isn't work (there's no
> rule for install target).
> Am I doing something wrong?
Well, that's hard to tell without more details about the error and your OS,
etc..
But have you tried without "-DWITH_DD=ON"? Do you need it?
Daniel
> From: daniel at georepublic.de
> Date: Wed, 21 Nov 2012 20:39:59 +0900
> To: pgrouting-users at lists.osgeo.org
> Subject: Re: [pgrouting-users] FW: Multiple queries in a row
> There is something, but it didn't make it yet into pgRouting master branch:
> https://github.com/pgRouting/pgrouting/wiki/APSP
> You can find it in this branch:
> https://github.com/pgRouting/pgrouting/tree/gsoc-tdsp
> Daniel
> On Wed, Nov 21, 2012 at 8:05 PM, Tao Romera Martinez <taoromera at gmail.com>wrote:
> Hi Iñigo,
> I needed to do something similar to what you are trying to do some time
> ago and asked in the list. Unfortunately, it is not possible to retrieve
> several shortest paths in one run. It is certainly possible to reduce the
> time needed to perform the shortest path routing between a set of nodes,
> but for this the code of the shortest_path C function should be modified to
> fetch the road network data it needs from the DB only once and then perform
> the routing algorithm several times.
> Tao
> 2012/11/21 Iñigo Vázquez <ivgwildchild666 at hotmail.com>
> Thanks for your reply, but in my case the shortest path doesn`t interest
> me. I need the shortest paths from one given node to each others beacuse
> then I want to calculate a path taking into account a given time limit.
> Something like in the "Traveling Salesman Problem" but with Time Window.
> Thanks!
> From: gunnar at tradlosetrondheim.no
> Date: Wed, 21 Nov 2012 11:08:03 +0100
> Subject: Re: [pgrouting-users] Multiple queries in a row
> CC: ivgwildchild666 at hotmail.com
> Hello,
> I do not know the answer to you question, but I might know an workarround
> if you are only interrested in the shortest of them.
> We use a hack to find the path to the closest node of a set of nodes.
> Basically we tweak the query which builds the graph to rename all nodes
> which are applicable to some id which cannot be found in the graph elsewere
> (e.g. -1), and the search for the path to this node.
> (NB: this could/would give strange beahviour if used with astar)
> Best regards Gunnar
> Dear all,
> I need to obtain a set of nearest nodes from a given location (maybe 30 or
> 40). Then I need to calculate the shortest path from the given node from
> each others. It means to execute shortes_path query multiple times in a
> row, wich takes about 2 seconds (1 query 2 seconds: 30 queries 60 -> too
> long).
> SELECT * FROM shortest_path('
>    SELECT id AS id,
>           source::int4 AS source,
>           target::int4 AS target,
>           cost::float8 AS cost
>    FROM tt_2po_4pgr',275742,274494,
> false,
> false)
> What would be the best way to do this in a reasonable time?
> Thank in advance!
> Pd: excuse my english
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>  Gunnar Rangøy  System developer  Trådløse Trondheim / Wireless Trondheim
> tradlosetrondheim.no  +47 99 36 06 99
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
> _______________________________________________ Pgrouting-users mailing
> list Pgrouting-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20121121/ad14971f/attachment-0001.html>
More information about the Pgrouting-users mailing list
