[pgrouting-users] FW: Multiple queries in a row
Daniel Kastl daniel at georepublic.de
Wed Nov 21 05:44:13 PST 2012
Sorry, the Wiki page says you need it.
But for DD (driving Distance) you need to install (compile) GAUL.
Daniel
On Wed, Nov 21, 2012 at 10:40 PM, Daniel Kastl <daniel at georepublic.de>wrote:
> On Wed, Nov 21, 2012 at 10:15 PM, Iñigo Vázquez <
> ivgwildchild666 at hotmail.com> wrote:
>> Nice! I think this should be valid for my case. But I'm having some
>> troubles in compilation/installation.
>> I've downloaded the .zip archive from github and I extracted it. From
>> "cmake" folder I execute this command "cmake -DWITH_DD=ON" and then,
>> when I try to execute this one "sudo make install"  isn't work (there's
>> no rule for install target).
>> Am I doing something wrong?
> Well, that's hard to tell without more details about the error and your
> OS, etc..
> But have you tried without "-DWITH_DD=ON"? Do you need it?
> Daniel
>> From: daniel at georepublic.de
>> Date: Wed, 21 Nov 2012 20:39:59 +0900
>> To: pgrouting-users at lists.osgeo.org
>> Subject: Re: [pgrouting-users] FW: Multiple queries in a row
>> There is something, but it didn't make it yet into pgRouting master
>> branch:
>> https://github.com/pgRouting/pgrouting/wiki/APSP
>> You can find it in this branch:
>> https://github.com/pgRouting/pgrouting/tree/gsoc-tdsp
>> Daniel
>> On Wed, Nov 21, 2012 at 8:05 PM, Tao Romera Martinez <taoromera at gmail.com
>> > wrote:
>> Hi Iñigo,
>> I needed to do something similar to what you are trying to do some time
>> ago and asked in the list. Unfortunately, it is not possible to retrieve
>> several shortest paths in one run. It is certainly possible to reduce the
>> time needed to perform the shortest path routing between a set of nodes,
>> but for this the code of the shortest_path C function should be modified to
>> fetch the road network data it needs from the DB only once and then perform
>> the routing algorithm several times.
>> Tao
>> 2012/11/21 Iñigo Vázquez <ivgwildchild666 at hotmail.com>
>> Thanks for your reply, but in my case the shortest path doesn`t interest
>> me. I need the shortest paths from one given node to each others beacuse
>> then I want to calculate a path taking into account a given time limit.
>> Something like in the "Traveling Salesman Problem" but with Time Window.
>> Thanks!
>> From: gunnar at tradlosetrondheim.no
>> Date: Wed, 21 Nov 2012 11:08:03 +0100
>> Subject: Re: [pgrouting-users] Multiple queries in a row
>> CC: ivgwildchild666 at hotmail.com
>> Hello,
>> I do not know the answer to you question, but I might know an workarround
>> if you are only interrested in the shortest of them.
>> We use a hack to find the path to the closest node of a set of nodes.
>> Basically we tweak the query which builds the graph to rename all nodes
>> which are applicable to some id which cannot be found in the graph elsewere
>> (e.g. -1), and the search for the path to this node.
>> (NB: this could/would give strange beahviour if used with astar)
>> Best regards Gunnar
>> Dear all,
>> I need to obtain a set of nearest nodes from a given location (maybe 30
>> or 40). Then I need to calculate the shortest path from the given node from
>> each others. It means to execute shortes_path query multiple times in a
>> row, wich takes about 2 seconds (1 query 2 seconds: 30 queries 60 -> too
>> long).
>> SELECT * FROM shortest_path('
>>    SELECT id AS id,
>>           source::int4 AS source,
>>           target::int4 AS target,
>>           cost::float8 AS cost
>>    FROM tt_2po_4pgr',275742,274494,
>> false,
>> false)
>> What would be the best way to do this in a reasonable time?
>> Thank in advance!
>> Pd: excuse my english
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>  Gunnar Rangøy  System developer  Trådløse Trondheim / Wireless Trondheim
>> tradlosetrondheim.no  +47 99 36 06 99
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: http://georepublic.de
>> _______________________________________________ Pgrouting-users mailing
>> list Pgrouting-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20121121/a78a9a93/attachment.html>
More information about the Pgrouting-users mailing list
