[pgrouting-users] osm2pgrouting oneway misreading
Tao Romera Martinez
taoromera at gmail.com
Tue Oct 2 00:34:00 PDT 2012
Hi Sylvain,
I think I was not able to import data using osm2pgrouting, so I
instead used osm2po.
Here is the memo I made for myself on how to use it:
IMPORTING DATA FROM OSM INTO THE DATABASE
1. Download osm2po from http://osm2po.de/download.php?lnk=osm2po-4.4.4a.zip
2. Install in for example /usr/share/osm2po:
sudo unzip /home/tao/Downloads/osm2po-4.4.4a.zip
3. Download osm file
4. Copy file to your osm2po folder:
sudo cp /home/tao/Downloads/map.osm ./
4. Convert OSM file to DB file:
sudo java -jar osm2po-core-4.4.4a-signed.jar prefix=at <file>.osm
5. Import DB file into database (username = postgres):
psql -U postgres -d <your_DB> -q -f "/usr/share/osm2po/at/at_2po_4pgr.sql"
Good luck,
Tao
2012/10/2 Sylvain Housseman <hsylvio at gmail.com>:
> Dear all,
> I think that something is wrong with osm2pgrouting:
> The code (Export2DB.cpp, called by osm2pgrouting.cpp) writes :
> if(way->oneway)
> row_data += TO_STR(way->length*1000000);
> else
> row_data += TO_STR(way->length);
> (this row_data will be the reverse_cost value)
> but after exporting france.osm I unfortunately observe that this condition
> never seems to be met:
> franceRouting=> select count (*) from ways where reverse_cost <> length;
> count
> 0
> (1 row)
> So I guess that the condition (way->oneway) is not appropriated...
> Does any version deal with this problem (or did I forget something when
> launching osm2pgrouting)?
> Thanks again for these great tools;
> HSylvio.
> BTW, the osm wiki page (http://wiki.openstreetmap.org/wiki/Key:oneway)
> explains that
> "Some tags (such as junction=roundabout, highway=motorway and others) imply
> oneway=yes. You don't need to add a oneway tag
> Values
> oneway=yes (discouraged alternative: "true", "1")
> oneway=no (discouraged alternative: "false", "0")
> oneway=-1 (discouraged alternative: "reverse")
> I did not understand yet how the XMLParser works, but could the problem be
> solved by changing the type of "bool oneway" to a string or char[?] in the
> "Way" class?
> Best,
> HSylvio.
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
