[pgrouting-users] Shortest path with Dijkstra going through a set of points
Tao Romera Martinez taoromera at gmail.com
Tue Sep 11 17:22:55 PDT 2012
CPU usage: 11%
Mem usage: 1.1%
Disk I/O (%wa): 0.2% (the first time, then 0%)
The results with the directed graph turned on are similar.
2012/9/12 Talin Salway <talin at codeforamerica.org>:
> What does your memory and CPU usage look like during execution? Is it 350ms
> of pure CPU, or is there disk IO? Are you hitting memory limits and
> swapping?
> I ask because there are some edge cases where pgRouting uses too much
> memory.If it hits disk, it'd slow down your query.
> On Sep 11, 2012 7:26 AM, "Stephen Woodbridge" <woodbri at swoodbridge.com>
> wrote:
>> Tao,
>> This seems like a long time, but I do not have any hard numbers to compare
>> it to. Can you post the query you are running for this?
>> For comparison, it would be interesting to compare performance for:
>> Dijkstra shortest path
>> AStar shortest path
>> TRSP shortest path (pass NULL for the restriction query)
>> For pgRouting, indexes are only used on the SQL side of things, like a
>> spatial index to select the edges in the network, and maybe an index on the
>> gid if you join the results back to the original edge table. Once the edges
>> are read into pgRouting C code to build the graph, the graph is all in
>> memory and the solution is all performed in memory, then the results are
>> passed back to the SQL.
>> -Steve
>> On 9/11/2012 8:33 AM, Tao Romera Martinez wrote:
>>> It is the size of the selected road links that I use on the shortest
>>> path query.
>>> The whole network has several millions.
>>> On 2012/09/11, at 20:53, Daniel Kastl <daniel at georepublic.de
>>> <mailto:daniel at georepublic.de>> wrote:
>>>>     Time taken by shortest_path: 350 ms
>>>>     Time taken by the SQL query passed to shortest_path: 25 ms
>>>>     Number of ways in the network: 4400
>>>> Is this your complete network or the size of the selected road links
>>>> that you use for your shortest path query?
>>>> Daniel
>>>> Georepublic UG & Georepublic Japan
>>>> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
>>>> Web: http://georepublic.de <http://georepublic.de/>
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.org <mailto:Pgrouting-users at lists.osgeo.org>
>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
