[pgrouting-users] pgRounting with PostGIS 2.0
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 10 06:33:13 PDT 2013
On 4/10/2013 8:48 AM, Luís de Sousa wrote:
> Hi Stephen and Daniel,
> I'd be glad to contribute, I believe I can invest a few hours per week.
> Besides that I'm working on a project where K-Shortest will be used, I
> can try to source some funding around it.
Luis,
Funding would be great if you can arrange it, K-Shorest path is one of
the algorithms that we would like to add to 2.0 so we might be able to
accelerate getting that moved into sew-devel-2_0 branch.
Regarding contributing, do you have any area(s) that you would like to
work on. We can use effort in all areas. I do not where your skills are
on the spectrum from developer <----> user, but there is no shortage of
tasks across the board.
Regards,
-Steve
> Regards,
> Luís
> On 9 April 2013 15:56, Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>> wrote:
> Hi All,
> The sew-devel-2_0 branch is what I'm currently working on. I do not
> have a release date because it depends on how much we decide to
> integrate into this branch and how much funding we can raise to
> support this effort.
> My general development goals is to try an make sure that at the end
> of each day (UTC-0500) that the branch is stable and compiles and
> builds on Linux and Windows.
> Currently it:
> * works with PostGIS 2.0
> * has had the source tree restructured to better support multiple devs
> * has TRSP merged into the tree
> * has had TSP solver replaced to remove GAUL dependency
> * has a new doc system integrated into the source tree
> * has a new test infrastructure integrated into the source tree
> * has some tests have been added to the source tree
> * has some bugs fixed
> * has some new graph analytic tools for detecting graph connectivity
> issues
> * installs as a postgresql extension on PG9.1+
> * has probably a few other things that I'm not remembering.
> Things that will change over time in this branch:
> * all functions will get a pgr_ prefix
> * all functions will get reviewed and probably restructured to be
> more consistent and allow users to easily switch between function
> * more algorithms from pull requests and GSoC projects will get
> pulled into the main respository
> * rewrite driving distance to drop CGAL and use postgis functions
> Look at this to get an idea:
> https://github.com/pgRouting/__pgrouting/wiki/2.0-__Development-Plan
> <https://github.com/pgRouting/pgrouting/wiki/2.0-Development-Plan>
> You can see a lot has been done and there is a lot more to do. A lot
> of the infrastructure work has been tackled and some of the low
> hanging fruit has been picked. Any offers for funding would be
> greatly appreciated and could help accelerate and/or prioritize
> features.
> This is currently stable and fairly close to the 1.0.5 functionality
> so if you are inclined to give it a try we would love to here about
> on what works and doesn't, etc.
> Thanks,
> -Steve
> On 4/9/2013 9:22 AM, Luís de Sousa wrote:
> Hi Daniel, thanks for the update.
> I know this is a tricky question, but is there any expected date for
> this new release?
> Thank you,
> Luís
> On 9 April 2013 13:05, Daniel Kastl <daniel at georepublic.de
> <mailto:daniel at georepublic.de>
> <mailto:daniel at georepublic.de <mailto:daniel at georepublic.de>>__>
> wrote:
> A new release is currently worked on.
> There is lots of discussion on the developer list and if
> you want to
> try out, you could checkout from Github repository and
> compile using
> the following branch:
> https://github.com/pgrouting/__pgrouting/tree/sew-devel-2_0
> <https://github.com/pgrouting/pgrouting/tree/sew-devel-2_0>
> _________________________________________________
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.__org
> <mailto:Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
> <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
More information about the Pgrouting-users
