[pgrouting-users] Make pgrouting doesn't find postgres include dirs
Ian Tangert itangert at gmail.com
Thu Aug 1 05:25:29 PDT 2013
thanks dave and steve,
now it built and installed successfully.
it took three more things:
1) adding #include <sstream> to k_targets_boost_wrapper.cpp
2)changing #include "boost/property_map/property_map.hpp" to #include
"boost/property_map.hpp" in
./src/apsp_johnson/src/apsp_johnson_boost_wrapper.cpp
3)adding to ./src/tsp/src/tsp2.c just under the line #include <math.h>:
        #ifndef INIFINITY
        # define INFINITY (1.0/0.0)
        #endif
best,
ian
On Thu, Aug 1, 2013 at 5:11 AM, Dave Potts <dave.potts at pinan.co.uk> wrote:
> On 01/08/13 05:03, Stephen Woodbridge wrote:
> hi Ian,
> I am running this software on Ubunto 12.04
> I had some initial build issues mainly sorted by upgrade bits and bobs.
> I am running
> cmake 2.8.11
> gcc version 4.6.3
> bootst version 1.4.8
> postgis  POSTGIS="2.0.0 r9605" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6
> March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8"
> LIBJSON="UNKNOWN" RASTER
> The development version compiles out of the box.
> I not suggesting that you upgrade to any of these versions, but its a set
> up that works.
> regards
> Dave
>  Ian,
>> This looks like something involving the includes in your old version of
>> gcc. I'm running gcc version 4.7.2 (Debian 4.7.2-5) which is very new, but
>> I also was compiling with gcc version 4.3.2 (Debian 4.3.2-1.1) and had no
>> problems with that.
>> You might try adding to k_targets_boost_wrapper.cpp:
>> #include <sstream>
>> It might need to be explicitly included on your version.
>> -Steve
>> On 7/31/2013 4:26 PM, Ian Tangert wrote:
>>> Thanks Steve,
>>> I got alot farther with pgrouting 2.0 over 1.05 but the make && make
>>> install stopped with the following error:
>>> /sources/pgrouting/src/**kdijkstra/src/k_targets_boost_**wrapper.cpp: In
>>> function ‘std::string toString(T)’:
>>> wrapper.cpp:282:
>>> error: invalid use of undefined type ‘struct std::stringstream’
>>> /usr/lib/gcc/x86_64-redhat-**linux/4.1.2/../../../../**include/c++/4.1.2/iosfwd:83:
>>> error: declaration of ‘struct std::stringstream’
>>> make[2]: ***
>>> [src/kdijkstra/src/CMakeFiles/**kdijkstra.dir/k_targets_boost_**wrapper.cpp.o]
>>> Error 1
>>> make[1]: *** [src/kdijkstra/src/CMakeFiles/**kdijkstra.dir/all] Error 2
>>> make: *** [all] Error 2
>>> a few things i did:
>>> i had to change the following cgal reference in the CMakeCache.txt
>>>    =/usr/local/cgal/3.6.1/lib/**libCGAL.so
>>> Also, my make was:
>>>    make -DWITH_DD=ON -WITH_TSP=ON .
>>>        configuring done, generating done, no errors
>>> make && make install
>>> targets for trsp, astar, and dijkstra were built, but I don't understand
>>> what the     new error means
>>> On Wed, Jul 31, 2013 at 3:27 PM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>>> wrote:
>>>     Hi Ian,
>>>     What version of pgRouting are you trying to install?
>>>     I strongly recommend us 2.0.0 which is in beta and far more stable
>>>     than 1.05.
>>>     git clone https://github.com/pgRouting/_**_pgrouting.git<https://github.com/pgRouting/__pgrouting.git>
>>>     <https://github.com/pgRouting/**pgrouting.git<https://github.com/pgRouting/pgrouting.git>
>>>     cd pgrouting
>>>     git checkout develop
>>>     mkdir build
>>>     cd build
>>>     cmake  -DWITH_DD=ON ..
>>>     make && sudo make install
>>>     cd ..
>>>     tools/test-runner.pl <http://test-runner.pl>
>>>     Read this for more information:
>>>     https://github.com/pgRouting/_**_pgrouting/tree/develop<https://github.com/pgRouting/__pgrouting/tree/develop>
>>>     <https://github.com/pgRouting/**pgrouting/tree/develop<https://github.com/pgRouting/pgrouting/tree/develop>
>>>     -Steve
>>>     On 7/31/2013 3:10 PM, Ian Tangert wrote:
>>>         hello,
>>>         when i run make i get the following errors
>>>         make
>>>         [  8%] Building C object
>>>         extra/tsp/src/CMakeFiles/__**routing_tsp.dir/tsp.o
>>>         In file included from
>>>         /usr/pgsql-9.1/include/server/**__nodes/execnodes.h:17,
>>>                            from
>>>         /usr/pgsql-9.1/include/server/**__executor/execdesc.h:18,
>>>                            from
>>>         /usr/pgsql-9.1/include/server/**__executor/executor.h:17,
>>>                            from
>>>         /usr/pgsql-9.1/include/server/**__funcapi.h:21,
>>>                            from
>>>         /sources/pgrouting/pgrouting/_**_extra/tsp/src/tsp.c:26:
>>>         if i edit the the files listed in the error output above so that
>>> the
>>>         line that says #include "node/somefile.h" has the full path to
>>>         the file
>>>         to be included (/usr/pgsql-9.1/include/__**
>>> server/node/somefile.h)
>>>         then the
>>>         make command no longer produces an error.  but any time there is
>>>         a new
>>>         file to be included i need to edit the first file to include the
>>>         full
>>>         path and on and on.  Is there something i am missing so that
>>>         that the
>>>         pgrouting make "knows" that everything can be found somewhere in
>>>         /usr/pgsql-9.1/include?
>>>         my CMakeCahce.txt file looks like this:
>>> POSTGRESQL_INCLUDE_DIR:__**FILEPATH=/usr/pgsql-9.1/__**include
>>>         I am trying to install this on CentOS 5.5 with a postgresql
>>>         installation
>>>         that came from 9.1.9-1PGDG.rhel5, postgis also successfully
>>>         installed
>>>         and extension created in database
>>>         would it work if i just kept adding the full path in the include
>>>         line in
>>>         the *.h files, and if I did would that mess anything up for
>>>         postgres in
>>>         general?
>>>         thanks for any advice
>>>         ps my cmake -DWITH_TSP=ON -DWITH_DD=ON . output looks like this:
>>>         Boost headers were found here: /usr/include
>>>         Output directory for libraries is set to /usr/pgsql-9.1/lib
>>>         Installation directory for libraries is set to
>>>         /usr/pgsql-9.1/lib and
>>>         for SQL files is set to /usr/share/pgrouting
>>>         Installation directory for libraries is set to /usr/pgsql-9.1/lib
>>>         -- Configuring done
>>>         -- Generating done
>>>         -- Build files have been written to: /sources/pgrouting/pgrouting
>>>         ______________________________**___________________
>>>         Pgrouting-users mailing list
>>>         Pgrouting-users at lists.osgeo.__**org
>>>         <mailto:Pgrouting-users at lists.**osgeo.org<Pgrouting-users at lists.osgeo.org>
>>> http://lists.osgeo.org/__**mailman/listinfo/pgrouting-__**users<http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users>
>>> <http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130801/6374067c/attachment.html>
More information about the Pgrouting-users mailing list
