[pgrouting-users] Make pgrouting doesn't find postgres include dirs
Dave Potts
dave.potts at pinan.co.uk
Thu Aug 1 06:39:03 PDT 2013
On 01/08/13 14:25, Ian Tangert wrote:
> thanks dave and steve,
> now it built and installed successfully.
> it took three more things:
> 1) adding #include <sstream> to k_targets_boost_wrapper.cpp
> 2)changing #include "boost/property_map/property_map.hpp" to #include
> "boost/property_map.hpp" in
> ./src/apsp_johnson/src/apsp_johnson_boost_wrapper.cpp
> 3)adding to ./src/tsp/src/tsp2.c just under the line #include <math.h>:
> #ifndef INIFINITY
> # define INFINITY (1.0/0.0)
> #endif
> best,
I think you need to open a ticket on these issues,see
https://github.com/pgRouting/pgrouting/issues/new
Dave.
> ian
> On Thu, Aug 1, 2013 at 5:11 AM, Dave Potts <dave.potts at pinan.co.uk
> <mailto:dave.potts at pinan.co.uk>> wrote:
> On 01/08/13 05:03, Stephen Woodbridge wrote:
> hi Ian,
> I am running this software on Ubunto 12.04
> I had some initial build issues mainly sorted by upgrade bits and
> bobs.
> I am running
> cmake 2.8.11
> gcc version 4.6.3
> bootst version 1.4.8
> postgis POSTGIS="2.0.0 r9605" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel.
> 4.8.0, 6 March 2012" GDAL="GDAL 1.9.2, released 2012/10/08"
> LIBXML="2.7.8" LIBJSON="UNKNOWN" RASTER
> The development version compiles out of the box.
> I not suggesting that you upgrade to any of these versions, but
> its a set up that works.
> regards
> Dave
> Ian,
> This looks like something involving the includes in your old
> version of gcc. I'm running gcc version 4.7.2 (Debian 4.7.2-5)
> which is very new, but I also was compiling with gcc version
> 4.3.2 (Debian 4.3.2-1.1) and had no problems with that.
> You might try adding to k_targets_boost_wrapper.cpp:
> #include <sstream>
> It might need to be explicitly included on your version.
> -Steve
> On 7/31/2013 4:26 PM, Ian Tangert wrote:
> Thanks Steve,
> I got alot farther with pgrouting 2.0 over 1.05 but the
> make && make
> install stopped with the following error:
> /sources/pgrouting/src/kdijkstra/src/k_targets_boost_wrapper.cpp:
> In
> function 'std::string toString(T)':
> /sources/pgrouting/src/kdijkstra/src/k_targets_boost_wrapper.cpp:282:
> error: invalid use of undefined type 'struct
> std::stringstream'
> /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../include/c++/4.1.2/iosfwd:83:
> error: declaration of 'struct std::stringstream'
> make[2]: ***
> [src/kdijkstra/src/CMakeFiles/kdijkstra.dir/k_targets_boost_wrapper.cpp.o]
> Error 1
> make[1]: ***
> [src/kdijkstra/src/CMakeFiles/kdijkstra.dir/all] Error 2
> make: *** [all] Error 2
> a few things i did:
> i had to change the following cgal reference in the
> CMakeCache.txt
> =/usr/local/cgal/3.6.1/lib/libCGAL.so
> Also, my make was:
> make -DWITH_DD=ON -WITH_TSP=ON .
> configuring done, generating done, no errors
> make && make install
> targets for trsp, astar, and dijkstra were built, but I
> don't understand
> what the new error means
> On Wed, Jul 31, 2013 at 3:27 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>
> <mailto:woodbri at swoodbridge.com>>> wrote:
> Hi Ian,
> What version of pgRouting are you trying to install?
> I strongly recommend us 2.0.0 which is in beta and far
> more stable
> than 1.05.
> git clone https://github.com/pgRouting/__pgrouting.git
> <https://github.com/pgRouting/pgrouting.git>
> cd pgrouting
> git checkout develop
> mkdir build
> cd build
> cmake -DWITH_DD=ON ..
> make && sudo make install
> cd ..
> tools/test-runner.pl <http://test-runner.pl>
> Read this for more information:
> https://github.com/pgRouting/__pgrouting/tree/develop
> <https://github.com/pgRouting/pgrouting/tree/develop>
> -Steve
> On 7/31/2013 3:10 PM, Ian Tangert wrote:
> hello,
> when i run make i get the following errors
> make
> [ 8%] Building C object
> extra/tsp/src/CMakeFiles/__routing_tsp.dir/tsp.o
> In file included from
> /usr/pgsql-9.1/include/server/__nodes/execnodes.h:17,
> from
> /usr/pgsql-9.1/include/server/__executor/execdesc.h:18,
> from
> /usr/pgsql-9.1/include/server/__executor/executor.h:17,
> from
> /usr/pgsql-9.1/include/server/__funcapi.h:21,
> from
> /sources/pgrouting/pgrouting/__extra/tsp/src/tsp.c:26:
> if i edit the the files listed in the error output
> above so that the
> line that says #include "node/somefile.h" has the
> full path to
> the file
> to be included
> (/usr/pgsql-9.1/include/__server/node/somefile.h)
> then the
> make command no longer produces an error. but any
> time there is
> a new
> file to be included i need to edit the first file
> to include the
> full
> path and on and on. Is there something i am
> missing so that
> that the
> pgrouting make "knows" that everything can be
> found somewhere in
> /usr/pgsql-9.1/include?
> my CMakeCahce.txt file looks like this:
> POSTGRESQL_INCLUDE_DIR:__FILEPATH=/usr/pgsql-9.1/__include
> I am trying to install this on CentOS 5.5 with a
> postgresql
> installation
> that came from 9.1.9-1PGDG.rhel5, postgis also
> successfully
> installed
> and extension created in database
> would it work if i just kept adding the full path
> in the include
> line in
> the *.h files, and if I did would that mess
> anything up for
> postgres in
> general?
> thanks for any advice
> ps my cmake -DWITH_TSP=ON -DWITH_DD=ON . output
> looks like this:
> Boost headers were found here: /usr/include
> Output directory for libraries is set to
> /usr/pgsql-9.1/lib
> Installation directory for libraries is set to
> /usr/pgsql-9.1/lib and
> for SQL files is set to /usr/share/pgrouting
> /usr/pgsql-9.1/lib
> -- Configuring done
> -- Generating done
> -- Build files have been written to:
> _________________________________________________
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.__org
> <mailto:Pgrouting-users at lists.osgeo.org
> <mailto:Pgrouting-users at lists.osgeo.org>>
> http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
> <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130801/9762b52d/attachment-0001.html>
More information about the Pgrouting-users
