[pgrouting-users] pgr_createTopology
Stephen Mather stephen at smathermather.com
Mon Dec 2 18:54:14 PST 2013
I don't know if I did this correctly, but:
https://github.com/pgRouting/pgrouting/pull/221
On Sat, Nov 30, 2013 at 4:43 PM, Stephen Mather
<stephen at smathermather.com>wrote:
> Done.  Issue #220 <https://github.com/pgRouting/pgrouting/issues/220>.
> Thanks,
> Best,
> Steve
> On Sat, Nov 30, 2013 at 2:52 PM, Stephen Mather <stephen at smathermather.com
> > wrote:
>> Cool, I'll write a ticket.  It would be mostly useful in the case of e.g.
>> tutorial development.
>> Best,
>> Steve
>> On Sat, Nov 30, 2013 at 2:46 PM, Stephen Woodbridge <
>> woodbri at swoodbridge.com> wrote:
>>> On 11/30/2013 2:18 PM, Stephen Mather wrote:
>>>> Is pgr_createTopology deterministic in how it numbers nodes in a built
>>>> topology?
>>> Stephen,
>>> What do you mean by this?
>>> If you build a topology on the same edge table twice, do we guarantee
>>> that the nodes numbers will be identical?
>>> I think the answer is NO, on line:303 of src/common/sql/pgrouting_topology.sql
>>> there is no "order by" clause. This would need to be added to make it
>>> deterministic because relational set theory does not guarantee order of
>>> records in a query without explicitly including and "order by" clause.
>>> Write a bug if you think this is needed and state why.
>>> Thanks,
>>>   -Steve
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20131202/f44fd7f1/attachment.html>
More information about the Pgrouting-users mailing list
