[pgrouting-users] Problem when running osm2pgrouting
maruf rahman maruf.csdu at gmail.com
Thu Feb 21 07:31:52 PST 2013
OS: Ubuntu 12.04
I have installed pgrouting dependencies using this url
https://gist.github.com/djq/2846196
and pgrouting using this tutorial http://pgrouting.org/docs/1.x/install.html
and didn't use LiveDVD.
Please let me know if any more info is needed.
Maruf
On Thu, Feb 21, 2013 at 8:59 PM, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Maruf,
> Can you provide more information?
> Like which OS you use, how you installed pgRouting, etc..
> Do you use the OSGeo LiveDVD?
> Daniel
>  On Thu, Feb 21, 2013 at 11:38 PM, maruf rahman <maruf.csdu at gmail.com>wrote:
>>  Hi
>> I am trying to use pgrouting following this tutorial<http://workshop.pgrouting.org/index.html>.
>> Currently I am in section 4.2<http://workshop.pgrouting.org/chapters/osm2pgrouting.html>.
>> However when I try to execute the command of section 4.2, it only creates 3
>> tables name *classes, nodes* and *types*. But the document says, it
>> should create 8 tables.
>> Where is the problem? How can I solve this?
>> Thanks
>> Maruf
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130221/210e5fe7/attachment.html>
More information about the Pgrouting-users mailing list
