[pgrouting-users] Problem when running osm2pgrouting
Daniel Kastl daniel at georepublic.de
Thu Feb 21 07:46:22 PST 2013
Hi Maruf,
Looking at the Gist, there is no need anymore to compile PostGIS 2.0,
because it already has packages in the UbuntuGIS unstable repository.
It furthermore installs pgRouting as packages as well as osm2pgrouting,
which is good.
I don't know, why it doesn't work in your case and why you're missing
tables. Well, there is a t least one issue with osm2pgrouting when using
PostGIS 2.0, which requires some hack. And you may have to load
"legacy.sql".
Just a few days ago I updated the pgRouting installer for the new OSGeo
Live DVD and that it is working has been confirmed by several people:
http://trac.osgeo.org/osgeo/browser/livedvd/gisvm/branches/osgeolive_6_5/bin/install_pgrouting.sh
So maybe this OSGeo Live install script is more up-to-date. Because
pgRouting/osm2pgrouting still may have issues with PostGIS 2.0, you either
need to fix some wrapper SQL functions or load legacy.sql to your database
(see line #97).
And the hack for osm2pgrouting is from line #138.
Daniel
On Fri, Feb 22, 2013 at 12:31 AM, maruf rahman <maruf.csdu at gmail.com> wrote:
> OS: Ubuntu 12.04
> I have installed pgrouting dependencies using this url
> https://gist.github.com/djq/2846196
>  and pgrouting using this tutorial
> http://pgrouting.org/docs/1.x/install.html
> and didn't use LiveDVD.
> Please let me know if any more info is needed.
> Maruf
> On Thu, Feb 21, 2013 at 8:59 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>> Hi Maruf,
>> Can you provide more information?
>> Like which OS you use, how you installed pgRouting, etc..
>> Do you use the OSGeo LiveDVD?
>> Daniel
>>  On Thu, Feb 21, 2013 at 11:38 PM, maruf rahman <maruf.csdu at gmail.com>wrote:
>>>  Hi
>>> I am trying to use pgrouting following this tutorial<http://workshop.pgrouting.org/index.html>.
>>> Currently I am in section 4.2<http://workshop.pgrouting.org/chapters/osm2pgrouting.html>.
>>> However when I try to execute the command of section 4.2, it only creates 3
>>> tables name *classes, nodes* and *types*. But the document says, it
>>> should create 8 tables.
>>> Where is the problem? How can I solve this?
>>> Thanks
>>> Maruf
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130222/408311ab/attachment-0001.html>
More information about the Pgrouting-users mailing list
