[pgrouting-users] Problem when running osm2pgrouting
maruf rahman
maruf.csdu at gmail.com
Thu Feb 21 07:59:17 PST 2013
Hi Daniel,
I have run the script using *bash ./install_pgrouting.sh
Please check a part of output here <http://paste.ubuntu.com/1699747/>. Its
missing sample data and there are some database issue.
Thanks
Maruf
On Thu, Feb 21, 2013 at 9:46 PM, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Maruf,
> Looking at the Gist, there is no need anymore to compile PostGIS 2.0,
> because it already has packages in the UbuntuGIS unstable repository.
> It furthermore installs pgRouting as packages as well as osm2pgrouting,
> which is good.
> I don't know, why it doesn't work in your case and why you're missing
> tables. Well, there is a t least one issue with osm2pgrouting when using
> PostGIS 2.0, which requires some hack. And you may have to load
> "legacy.sql".
> Just a few days ago I updated the pgRouting installer for the new OSGeo
> Live DVD and that it is working has been confirmed by several people:
> http://trac.osgeo.org/osgeo/browser/livedvd/gisvm/branches/osgeolive_6_5/bin/install_pgrouting.sh
> So maybe this OSGeo Live install script is more up-to-date. Because
> pgRouting/osm2pgrouting still may have issues with PostGIS 2.0, you either
> need to fix some wrapper SQL functions or load legacy.sql to your database
> (see line #97).
> And the hack for osm2pgrouting is from line #138.
> Daniel
> On Fri, Feb 22, 2013 at 12:31 AM, maruf rahman <maruf.csdu at gmail.com>wrote:
>> OS: Ubuntu 12.04
>> I have installed pgrouting dependencies using this url
>> https://gist.github.com/djq/2846196
>> and pgrouting using this tutorial
>> http://pgrouting.org/docs/1.x/install.html
>> and didn't use LiveDVD.
>> Please let me know if any more info is needed.
>> Maruf
>> On Thu, Feb 21, 2013 at 8:59 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>>> Hi Maruf,
>>> Can you provide more information?
>>> Like which OS you use, how you installed pgRouting, etc..
>>> Do you use the OSGeo LiveDVD?
>>> Daniel
>>> On Thu, Feb 21, 2013 at 11:38 PM, maruf rahman <maruf.csdu at gmail.com>wrote:
>>>> Hi
>>>> I am trying to use pgrouting following this tutorial<http://workshop.pgrouting.org/index.html>.
>>>> Currently I am in section 4.2<http://workshop.pgrouting.org/chapters/osm2pgrouting.html>.
>>>> However when I try to execute the command of section 4.2, it only creates 3
>>>> tables name *classes, nodes* and *types*. But the document says, it
>>>> should create 8 tables.
>>>> Where is the problem? How can I solve this?
>>>> Thanks
>>>> Maruf
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>> Georepublic UG & Georepublic Japan
>>> eMail: daniel.kastl at georepublic.de
>>> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130221/1dba1ce0/attachment.html>
More information about the Pgrouting-users
