[pgrouting-users] algo which allow negative cost
Dave Potts
dave.potts at pinan.co.uk
Tue Jul 9 04:50:00 PDT 2013
On 09/07/13 08:36, Tao Romera Martinez wrote:
If your thinking of using the TSP as solution, just remember that as far
as it concerned the route A-> B is the same as the cost of the journey B->A.
Dave.
> Well, I guess you will have to find a way of classifying the POIs, to
> include those that are more relevant preferentially in your route.
> In our case, we were using Foursquare spots as POIs, and the number of
> checkins as the "relevance value". Then we picked a set of the most
> popular and run the algorithm I described in my previous message.
> Good luck with your case!
> Tao
> 2013/7/9 Yaron Lev <yaron666 at gmail.com>:
>> Stephan, thanks again, the "VRP" reference was very illuminating.
>> Tao, thanks for sharing your solution, indeed i am using a similar approach
>> atm, (was the only feasible solution i was able to think of).
>> the key difference, is how i pick the poi (i am still looking/thinking about
>> better solutions),
>> for example in the "poi selection - naive approch" (picking the closest,
>> repeat and rinse)
>> where S- start point, P - poi, end point - dont really have an end point
>> (assuming 5 points)
>> BBxxxxxxxxxxxxxxA
>> BBxxxxxxxxxxxxxxx
>> BBxxxxxxxxxxxxxxx
>> BxxxxxxxxxxxxxxxA
>> Bxxxxxxxxxxxxxxxx
>> xxxxxxxxxxAxxxxxx
>> xxxxxxxxxxxxxxxxxx
>> xxxxxSxxxxxxxxxxxx
>> the algo will choose the right side(A), even though B side is more
>> profitable (depends on how u calculate, but i reken the point is clear)
>> because it will always start from the closest even if its a pitfall
>> to combat this initially i will try to cluster the poi's,
>> C - is array of poi, which holds the number of poi associated with this
>> point.
>> Cx has threshold - which increase with number of poi it contains
>> Cx has a score - each poi added
>> 1. arrange them by distance from one another (not very efficient)
>> 2. then start clustering them - loop
>> 2.1 pick closest, Cx=pn (x=1,n=1)
>> 2.2 if dist(Cx,pn)<C (threshold then) add it to Cx,
>> 2.3 Cx(lat),Cx(lon) is the center of mass of P1....Pn, where n is the number
>> of points on Cx
>> 2.4 increase C(threshold) -> so that Cx, with many poi's would be able to
>> "add points/poi" from a greater distance, thus giving advantage to Cx with
>> many points.
>> 2.5 increase C(score) - 1/dist (Cx,pn),
>> 2.5 else (from 2.2) continue to the next uncluttered P (n+1)(x+1)
>> 3. calc final score for C - Cx(final score) = Cscore*dist (Cx,S)
>> 4. arrange C by score, choose desired amount of C.
>> 5. flat C into D array (i.e putting it back to array of points)
>> 7. TSP on D
>> 8. connect D with shortest path
>> i am still not very happy with this, i would still appreciate ideas on how
>> to improve this. (especially because its inefficient)
>> thanks everyone for your help!
>> On Tue, Jul 9, 2013 at 5:06 AM, Tao Romera Martinez <taoromera at gmail.com>
>> wrote:
>>> Yaron,
>>> I had to solve a similar problem for one of our iPhone apps (Sanpo).
>>> We had a set of POIs, each with a different "interest" value, and we
>>> had to create a route that went through the most interesting POIs
>>> within a specified time.
>>> In our case, start and end point were the same (the user comes back to
>>> the starting point after the stroll).
>>> Since TSP was not suitable and you can not set negative cost values in
>>> Dijkstra, I ended up solving it this way:
>>> 1. Pick up a set of POIs from your POIs array (for example, 5 POIs among
>>> 10)
>>> 2. From the starting point, find the closest POI (not using the length
>>> of the route to that point, but straight line distance). Since we use
>>> straight line distances, calculating this distance takes nothing.
>>> 3. From the last POI, find the next closest POI we have still not
>>> visited. If no POIs left, find the distance from that POI to the end
>>> point.
>>> 4. In a urban context, real walking distances are in the order of
>>> (straight line distance) x 1.3, so estimate the walking distance of
>>> your "tour" using this formula. If it exceeds the required time, go to
>>> 1 and start over again.
>>> 5. Once you have the set of POIs you want to include in your route,
>>> connect each of them using Dijkstra (you will need to call Dijkstra
>>> several times and join the route between each pair of POIs manually)
>>> Since you are working with estimates using the formula in 4, it may
>>> not work if you need very precise walking time constraints. But if you
>>> intend to use it to create walking routes for tourism, I doubt this
>>> will be a problem. After all, you don't know how long people are going
>>> to stay at each POI.
>>> Tao
>>> 2013/7/9 Stephen Woodbridge <woodbri at swoodbridge.com>:
>>>> Right, what you are describing is known as "VRP with profits". The idea
>>>> is
>>>> that you have some number of locations that have a profit associated to
>>>> them
>>>> and typically you have some other constraints like the maximum time for
>>>> the
>>>> tour. Then you have to optimize the selection of locations based on the
>>>> maximum time and maximize profit for the tour.
>>>> This is not a simple shortest path algorithm. If you have no time
>>>> constraint, then you can just use TSP with the POI's that you want to
>>>> visit.
>>>> Specify a start point and the list of POIs as a distance matrix and TSP
>>>> will
>>>> optimize the order to visit the POIs based on making it the shortest
>>>> tour
>>>> length. As you mention, this forces the use of all points.
>>>> Otherwise, we do not have anything like this yet. Dijkstra with a
>>>> negative
>>>> cost does not solve this problem.
>>>> Thanks for taking the time to explain your needs. Feel free to add a
>>>> ticket
>>>> for a future enhancement. Please refer to "VRP with profits" in the
>>>> ticket
>>>> so we know what you are looking for.
>>>> Thanks,
>>>> -Steve
>>>> On 7/8/2013 12:49 PM, Yaron Lev wrote:
>>>>> Stephan i appreciate your help,
>>>>> this is not a game problem, this is a routing problem.
>>>>> i have some poi, such museums etc. i want to offer a route to my users
>>>>> which will be the shortest, and will pass through as many poi's as
>>>>> possible.
>>>>> if i just +1 other edges, nothing forces the algo, to go through those
>>>>> poi's.
>>>>> imagine the following where:
>>>>> F - poi
>>>>> E - end point
>>>>> S- start point
>>>>> FxxxxE
>>>>> xxxxxx
>>>>> xxxxxx
>>>>> xxxxxS
>>>>> using +1 technique the route will not pass through F, trust me i tried
>>>>> using the TSP approach, which i also tried, it forces the user go
>>>>> through all of the poi, regardless of there distance, which might be
>>>>> counter productive.
>>>>> thanks.
>>>>> On Mon, Jul 8, 2013 at 7:25 PM, Stephen Woodbridge
>>>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>>>> Why not just add 1.0 to all you edge costs so you minimum edge cost
>>>>> is 0 for fruits and 1+ for all other edges?
>>>>> I assume that a -1 cost just means that the edge is desirable to
>>>>> capture but is your goal is to collect some number of POI in an
>>>>> area, than it might be better to get the location of all the POI
>>>>> and
>>>>> the cost to get from each POI to each of the other POI then you can
>>>>> build a distance matrix to compute TSP solution which is the
>>>>> minimum
>>>>> cost to hit every POI.
>>>>> It is not clear to be what you want to achieve here. We do not have
>>>>> algorithms targeted at game theory or solving game like problems.
>>>>> So
>>>>> you have to re-map the problem into point to point shortest
>>>>> distance
>>>>> and multiple point order optimization problems.
>>>>> -Steve
>>>>> On 7/8/2013 12:19 PM, Yaron Lev wrote:
>>>>> Hi,
>>>>> i am wondering if there is any algo within pgrouting 2, which
>>>>> will allow
>>>>> edges to have negative costs (without negative circles)?
>>>>> i was not able to find such, and in this event, is there some
>>>>> clever
>>>>> way, to achieve a similar effect?
>>>>> in specific, i am trying to solve a pac-man like problem.
>>>>> trying to find best route, given graph, where on some edges
>>>>> there are
>>>>> "fruits" to collect, collecting fruits will have a positive
>>>>> effect.
>>>>> your goal to collect as many fruits as possible, fruit can have
>>>>> a
>>>>> -1
>>>>> cost for example while each edge has it length as a positive
>>>>> cost.
>>>>> the outcome should be a route, where at any distance(this is
>>>>> flexible,
>>>>> as long as it achieve a similar goal) from route, the outcome
>>>>> route will
>>>>> have the best score out of all other routes.
>>>>> i tried using shortest path algo, with out negative costs, but
>>>>> i
>>>>> am
>>>>> unable to come up with a solution which will indeed provide
>>>>> such
>>>>> or
>>>>> similar solution. (in specfic un able to come up with costs,
>>>>> which will
>>>>> indeed "force" the route to collect those "fruits")
>>>>> i will appreciate any insight or direction for solving this
>>>>> problem.
>>>>> * the fruits are actually poi, such as bus stations, museums
>>>>> etc.
>>>>> * if negative edge costs are allowed, the problem is solved.
>>>>> thanks for your help!
>>>>> _________________________________________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.__org
>>>>> <mailto:Pgrouting-users at lists.osgeo.org>
>>>>> http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
>>>>> <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
>>> Tao Romera MartÃnez
>>> Tel: 080-6805-0945
>>> Address: Koganei-shi, Tokyo, Japan
>>> Look for me on Facebook and LinkedIn
More information about the Pgrouting-users
