[pgrouting-users] suspected bug in TSP distance matrix pgRouting RC1 released
sanak
geosanak at gmail.com
Fri Jul 19 05:02:29 PDT 2013
Hi Dave, Stephen,
I encountered the same issue(
https://github.com/pgRouting/pgrouting/issues/159 ),
so, I sent the pull request(https://github.com/pgRouting/pgrouting/pull/160
> Stephen
Could you check my pull request?
Thanks,
2013/7/19 Dave Potts <dave.potts at pinan.co.uk>
> I have been trying to do some work which requires the tsp, some of my
> values have values of 0.1 in the dataset, I keep getting odd results.
> So I tried a well known example from the pgr _tsp distance page and it
> work as expected.
> I then repeated the same example but reduced all of the distance by a
> factor off 10 and got an error. Unless I have make a mistake in my
> understanding of the manual page, I think we might a problem where
> -- version used
> select pgr_version();
> pgr_version
> (2.0.0-dev,v2.0.0-rc1,0,**bf13fd7,develop,1.48.0)
> -- Use a example get a result set
> SELECT seq, id FROM pgr_tsp('{{0,1,3,3},{1,0,2,2},**
> {3,2,0,2},{3,2,2,0}}'::float8[**],1);
> seq | id
> 0 | 1
> 1 | 2
> 2 | 3
> 3 | 0
> (4 rows)
> -- repeat for reduce everything by scale factor of 10 ie 1.0 becomes 0.1
> etc
> SELECT seq, id FROM pgr_tsp('{{0,0.1,0.3,0.3},{0.**
> 1,0,0.2,0.2},{0.3,0.2,0,0.2},{**0.3,0.2,0.2,0}}'::float8[],1);
> ERROR: Error TSP fail to findEulerianPath, check your distance matrix is
> valid.
> As far as I understand it my matrix has 0's on the leading diangonal and
> [a,b] == [b,a]
> Dave.
> ______________________________**_________________
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
Ko Nagase (sanak)
Georepublic Japan
mail: geosanak at gmail.com
nagase at georepublic.co.jp
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130719/1b829698/attachment.html>
More information about the Pgrouting-users
