[pgrouting-users] suspected bug in TSP distance matrix pgRouting RC1 released
Dave Potts dave.potts at pinan.co.uk
Fri Jul 19 06:08:14 PDT 2013
On 19/07/13 13:02, sanak wrote:
Hi Sanak
Thanks for your help
I had the float version in my source base I changed it to a double, I
have done a make clean, install restarted the service, still have the
same problem :-(
Dave
> Hi Dave, Stephen,
> I encountered the same
> issue(https://github.com/pgRouting/pgrouting/issues/159 ),
> so, I sent the pull
> request(https://github.com/pgRouting/pgrouting/pull/160 ).
> > Stephen
> Could you check my pull request?
> Thanks,
> 2013/7/19 Dave Potts <dave.potts at pinan.co.uk
> <mailto:dave.potts at pinan.co.uk>>
>     I have been trying to do some work which requires the tsp, some of
>     my values have values of 0.1 in the dataset, I keep getting odd
>     results.
>     So I tried a well known example from the  pgr _tsp distance page
>     and it work as expected.
>     I then repeated the same example but reduced all of the distance
>     by a factor off 10 and got an error.  Unless I have make a mistake
>     in my understanding of the manual page, I think we might a problem
>     where
>     -- version used
>     select pgr_version();
>                        pgr_version
>      (2.0.0-dev,v2.0.0-rc1,0,bf13fd7,develop,1.48.0)
>     -- Use a example get a result set
>     SELECT seq, id FROM
>     pgr_tsp('{{0,1,3,3},{1,0,2,2},{3,2,0,2},{3,2,2,0}}'::float8[],1);
>      seq | id
>        0 |  1
>        1 |  2
>        2 |  3
>        3 |  0
>     (4 rows)
>     -- repeat for reduce everything by  scale factor of 10  ie 1.0
>     becomes 0.1 etc
>     SELECT seq, id FROM
>     pgr_tsp('{{0,0.1,0.3,0.3},{0.1,0,0.2,0.2},{0.3,0.2,0,0.2},{0.3,0.2,0.2,0}}'::float8[],1);
>     ERROR:  Error TSP fail to findEulerianPath, check your distance
>     matrix is valid.
>     As far as I understand it my matrix has 0's on the leading
>     diangonal  and [a,b] == [b,a]
>     Dave.
>     _______________________________________________
>     Pgrouting-users mailing list
>     Pgrouting-users at lists.osgeo.org
>     <mailto:Pgrouting-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Ko Nagase (sanak)
> Georepublic Japan
> mail: geosanak at gmail.com <mailto:geosanak at gmail.com>
> nagase at georepublic.co.jp <mailto:nagase at georepublic.co.jp>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130719/b74eb45b/attachment.html>
More information about the Pgrouting-users mailing list
