[pgrouting-users] Make pgrouting doesn't find postgres include dirs
Ian Tangert itangert at gmail.com
Wed Jul 31 14:41:34 PDT 2013
gcc-c++ --version is 4.1.2-54.
is it the case that this version is too old?
can i exclude only kdijkstra somehow?
i realize trying this on Centos5.5 is next to futile but the circumstances
are unusual
On Wed, Jul 31, 2013 at 4:51 PM, Ian Tangert <itangert at gmail.com> wrote:
> actually it looks like my gcc-c++ is out of date...checking on that
> On Wed, Jul 31, 2013 at 4:26 PM, Ian Tangert <itangert at gmail.com> wrote:
>> Thanks Steve,
>> I got alot farther with pgrouting 2.0 over 1.05 but the make && make
>> install stopped with the following error:
>> /sources/pgrouting/src/kdijkstra/src/k_targets_boost_wrapper.cpp: In
>> function ‘std::string toString(T)’:
>> /sources/pgrouting/src/kdijkstra/src/k_targets_boost_wrapper.cpp:282:
>> error: invalid use of undefined type ‘struct std::stringstream’
>> /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../include/c++/4.1.2/iosfwd:83:
>> error: declaration of ‘struct std::stringstream’
>> make[2]: ***
>> [src/kdijkstra/src/CMakeFiles/kdijkstra.dir/k_targets_boost_wrapper.cpp.o]
>> Error 1
>> make[1]: *** [src/kdijkstra/src/CMakeFiles/kdijkstra.dir/all] Error 2
>> make: *** [all] Error 2
>> a few things i did:
>> i had to change the following cgal reference in the CMakeCache.txt
>>   =/usr/local/cgal/3.6.1/lib/libCGAL.so
>> Also, my make was:
>>   make -DWITH_DD=ON -WITH_TSP=ON .
>>       configuring done, generating done, no errors
>> make && make install
>> targets for trsp, astar, and dijkstra were built, but I don't understand
>> what the     new error means
>> On Wed, Jul 31, 2013 at 3:27 PM, Stephen Woodbridge <
>> woodbri at swoodbridge.com> wrote:
>>> Hi Ian,
>>> What version of pgRouting are you trying to install?
>>> I strongly recommend us 2.0.0 which is in beta and far more stable than
>>> 1.05.
>>> git clone https://github.com/pgRouting/**pgrouting.git<https://github.com/pgRouting/pgrouting.git>
>>> cd pgrouting
>>> git checkout develop
>>> mkdir build
>>> cd build
>>> cmake  -DWITH_DD=ON ..
>>> make && sudo make install
>>> cd ..
>>> tools/test-runner.pl
>>> Read this for more information:
>>> https://github.com/pgRouting/**pgrouting/tree/develop<https://github.com/pgRouting/pgrouting/tree/develop>
>>> -Steve
>>> On 7/31/2013 3:10 PM, Ian Tangert wrote:
>>>> hello,
>>>> when i run make i get the following errors
>>>> make
>>>> [  8%] Building C object extra/tsp/src/CMakeFiles/**
>>>> routing_tsp.dir/tsp.o
>>>> In file included from /usr/pgsql-9.1/include/server/**
>>>> nodes/execnodes.h:17,
>>>> executor/execdesc.h:18,
>>>> executor/executor.h:17,
>>>>                   from /usr/pgsql-9.1/include/server/**funcapi.h:21,
>>>>                   from /sources/pgrouting/pgrouting/**
>>>> extra/tsp/src/tsp.c:26:
>>>> if i edit the the files listed in the error output above so that the
>>>> line that says #include "node/somefile.h" has the full path to the file
>>>> to be included (/usr/pgsql-9.1/include/**server/node/somefile.h) then
>>>> the
>>>> make command no longer produces an error.  but any time there is a new
>>>> file to be included i need to edit the first file to include the full
>>>> path and on and on.  Is there something i am missing so that that the
>>>> pgrouting make "knows" that everything can be found somewhere in
>>>> /usr/pgsql-9.1/include?
>>>> my CMakeCahce.txt file looks like this:
>>>>    POSTGRESQL_INCLUDE_DIR:**FILEPATH=/usr/pgsql-9.1/**include
>>>> I am trying to install this on CentOS 5.5 with a postgresql installation
>>>> that came from 9.1.9-1PGDG.rhel5, postgis also successfully installed
>>>> and extension created in database
>>>> would it work if i just kept adding the full path in the include line in
>>>> the *.h files, and if I did would that mess anything up for postgres in
>>>> general?
>>>> thanks for any advice
>>>> ps my cmake -DWITH_TSP=ON -DWITH_DD=ON . output looks like this:
>>>> Boost headers were found here: /usr/include
>>>> Output directory for libraries is set to /usr/pgsql-9.1/lib
>>>> Installation directory for libraries is set to /usr/pgsql-9.1/lib and
>>>> for SQL files is set to /usr/share/pgrouting
>>>> -- Configuring done
>>>> -- Generating done
>>>> -- Build files have been written to: /sources/pgrouting/pgrouting
>>>> ______________________________**_________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130731/f67080cd/attachment.html>
More information about the Pgrouting-users mailing list
