[pgrouting-users] Make pgrouting doesn't find postgres include dirs
Stephen Woodbridge woodbri at swoodbridge.com
Wed Jul 31 20:03:01 PDT 2013
Ian,
This looks like something involving the includes in your old version of
gcc. I'm running gcc version 4.7.2 (Debian 4.7.2-5) which is very new,
but I also was compiling with gcc version 4.3.2 (Debian 4.3.2-1.1) and
had no problems with that.
You might try adding to k_targets_boost_wrapper.cpp:
#include <sstream>
It might need to be explicitly included on your version.
-Steve
On 7/31/2013 4:26 PM, Ian Tangert wrote:
> Thanks Steve,
> I got alot farther with pgrouting 2.0 over 1.05 but the make && make
> install stopped with the following error:
> /sources/pgrouting/src/kdijkstra/src/k_targets_boost_wrapper.cpp: In
> function ‘std::string toString(T)’:
> /sources/pgrouting/src/kdijkstra/src/k_targets_boost_wrapper.cpp:282:
> error: invalid use of undefined type ‘struct std::stringstream’
> /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../include/c++/4.1.2/iosfwd:83:
> error: declaration of ‘struct std::stringstream’
> make[2]: ***
> [src/kdijkstra/src/CMakeFiles/kdijkstra.dir/k_targets_boost_wrapper.cpp.o]
> Error 1
> make[1]: *** [src/kdijkstra/src/CMakeFiles/kdijkstra.dir/all] Error 2
> make: *** [all] Error 2
> a few things i did:
> i had to change the following cgal reference in the CMakeCache.txt
>    =/usr/local/cgal/3.6.1/lib/libCGAL.so
> Also, my make was:
>    make -DWITH_DD=ON -WITH_TSP=ON .
>        configuring done, generating done, no errors
> make && make install
> targets for trsp, astar, and dijkstra were built, but I don't understand
> what the     new error means
> On Wed, Jul 31, 2013 at 3:27 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     Hi Ian,
>     What version of pgRouting are you trying to install?
>     I strongly recommend us 2.0.0 which is in beta and far more stable
>     than 1.05.
>     git clone https://github.com/pgRouting/__pgrouting.git
>     <https://github.com/pgRouting/pgrouting.git>
>     cd pgrouting
>     git checkout develop
>     mkdir build
>     cd build
>     cmake  -DWITH_DD=ON ..
>     make && sudo make install
>     cd ..
>     tools/test-runner.pl <http://test-runner.pl>
>     Read this for more information:
>     https://github.com/pgRouting/__pgrouting/tree/develop
>     <https://github.com/pgRouting/pgrouting/tree/develop>
>     -Steve
>     On 7/31/2013 3:10 PM, Ian Tangert wrote:
>         hello,
>         when i run make i get the following errors
>         make
>         [  8%] Building C object
>         extra/tsp/src/CMakeFiles/__routing_tsp.dir/tsp.o
>         In file included from
>         /usr/pgsql-9.1/include/server/__nodes/execnodes.h:17,
>                            from
>         /usr/pgsql-9.1/include/server/__executor/execdesc.h:18,
>                            from
>         /usr/pgsql-9.1/include/server/__executor/executor.h:17,
>                            from
>         /usr/pgsql-9.1/include/server/__funcapi.h:21,
>                            from
>         /sources/pgrouting/pgrouting/__extra/tsp/src/tsp.c:26:
>         if i edit the the files listed in the error output above so that the
>         line that says #include "node/somefile.h" has the full path to
>         the file
>         to be included (/usr/pgsql-9.1/include/__server/node/somefile.h)
>         then the
>         make command no longer produces an error.  but any time there is
>         a new
>         file to be included i need to edit the first file to include the
>         full
>         path and on and on.  Is there something i am missing so that
>         that the
>         pgrouting make "knows" that everything can be found somewhere in
>         /usr/pgsql-9.1/include?
>         my CMakeCahce.txt file looks like this:
>             POSTGRESQL_INCLUDE_DIR:__FILEPATH=/usr/pgsql-9.1/__include
>         I am trying to install this on CentOS 5.5 with a postgresql
>         installation
>         that came from 9.1.9-1PGDG.rhel5, postgis also successfully
>         installed
>         and extension created in database
>         would it work if i just kept adding the full path in the include
>         line in
>         the *.h files, and if I did would that mess anything up for
>         postgres in
>         general?
>         thanks for any advice
>         ps my cmake -DWITH_TSP=ON -DWITH_DD=ON . output looks like this:
>         Boost headers were found here: /usr/include
>         Output directory for libraries is set to /usr/pgsql-9.1/lib
>         Installation directory for libraries is set to
>         /usr/pgsql-9.1/lib and
>         for SQL files is set to /usr/share/pgrouting
>         Installation directory for libraries is set to /usr/pgsql-9.1/lib
>         -- Configuring done
>         -- Generating done
>         -- Build files have been written to: /sources/pgrouting/pgrouting
>         _________________________________________________
>         Pgrouting-users mailing list
>         Pgrouting-users at lists.osgeo.__org
>         <mailto:Pgrouting-users at lists.osgeo.org>
>         http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
>         <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
More information about the Pgrouting-users mailing list
