[pgrouting-users] pgr_dijkstra not returning edge IDs
Michael Wagner wagm at gmx.de
Thu Jun 27 22:25:53 PDT 2013
Dear Sanak,
Many thanks for your swift reply. I saw your ticket only after I posted
mine, sorry for posting it again!
Cheers,
Michael
On 28/06/2013 09:22, sanak wrote:
> Hi Michael,
> Thanks for your report.
> I also confirmed above issue, and created the
> ticket(https://github.com/pgRouting/pgrouting/issues/137 ).
> The cause of this issue may be memory related one,
> and we will try to fix this issue as soon as possible.
> Regards,
> 2013/6/28 mw_boness <wagm at gmx.de <mailto:wagm at gmx.de>>
>     Dear pgRouting Team,
>     I am using the current developer version of pgRouting (2.0.0-dev)
>     on Windows
>     8, 64Bit with PostgreSQL 9.2 and PostGIS 2.0. When I am running the
>     pgr_dijkstra(...) procedure the edge id column contains only zeros
>     while the
>     nodes are perfectly fine. That happens with my own dataset as well
>     as with
>     the pgRouting sample dataset (have a look at the screenshot). The
>     pgr_ksp(...) procedure does currently crash the PostgreSQL Server
>     everytime
>     it is run.
>     If you have any hint on how the get the edge IDs that would be most
>     appreciated.
>     Many thanks,
>     Michael
>     <http://pgrouting-users.974093.n3.nabble.com/file/n4025197/shot.png>
>     View this message in context:
>     http://pgrouting-users.974093.n3.nabble.com/pgr-dijkstra-not-returning-edge-IDs-tp4025197.html
>     Sent from the pgRouting-users mailing list archive at Nabble.com.
>     _______________________________________________
>     Pgrouting-users mailing list
>     Pgrouting-users at lists.osgeo.org
>     <mailto:Pgrouting-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Ko Nagase (sanak)
> Georepublic Japan
> mail: geosanak at gmail.com <mailto:geosanak at gmail.com>
> nagase at georepublic.co.jp <mailto:nagase at georepublic.co.jp>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130628/484bdb8c/attachment.html>
More information about the Pgrouting-users mailing list
