[pgrouting-users] pgr_dijkstra not returning edge IDs
sanak geosanak at gmail.com
Thu Jun 27 22:22:07 PDT 2013
Hi Michael,
Thanks for your report.
I also confirmed above issue, and created the ticket(
https://github.com/pgRouting/pgrouting/issues/137 ).
The cause of this issue may be memory related one,
and we will try to fix this issue as soon as possible.
Regards,
2013/6/28 mw_boness <wagm at gmx.de>
> Dear pgRouting Team,
> I am using the current developer version of pgRouting (2.0.0-dev) on
> Windows
> 8, 64Bit with PostgreSQL 9.2 and PostGIS 2.0. When I am running the
> pgr_dijkstra(...) procedure the edge id column contains only zeros while
> the
> nodes are perfectly fine. That happens with my own dataset as well as with
> the pgRouting sample dataset (have a look at the screenshot). The
> pgr_ksp(...) procedure does currently crash the PostgreSQL Server everytime
> it is run.
> If you have any hint on how the get the edge IDs that would be most
> appreciated.
> Many thanks,
> Michael
> <http://pgrouting-users.974093.n3.nabble.com/file/n4025197/shot.png>
> http://pgrouting-users.974093.n3.nabble.com/pgr-dijkstra-not-returning-edge-IDs-tp4025197.html
> Sent from the pgRouting-users mailing list archive at Nabble.com.
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Ko Nagase (sanak)
Georepublic Japan
mail: geosanak at gmail.com
        nagase at georepublic.co.jp
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130628/2f04be96/attachment.html>
More information about the Pgrouting-users mailing list
