[pgrouting-users] PGRouting and Postgresql 9.2
Stephen Woodbridge woodbri at swoodbridge.com
Mon Mar 4 21:51:47 PST 2013
On 3/5/2013 12:15 AM, Pieter du Plooy wrote:
> Stephen
> I essentially took the pgrouting4w-master from
> https://github.com/sanak/pgrouting4w, and followed the guide from the
> Build.mingw file.  I had problems building boost, but followed
> http://stackoverflow.com/questions/5299468/unable-to-build-boost-libraries-with-gcc
> to build bjam and then boost.
> I am attaching an winrar file with the dll's as well as the sql files
> which I modified according to Linux procedures as Postgres 9.2 uses
> LANGUAGE 'c' instead of LANGUAGE  'C' .
Pieter,
Thank you for this it will save me a bunch of time once I tackle this.
> I would also like the ability to have pgrouting to be installed as
> Postgres 9.2 extensions in stead of doing a psql -f on all the sql
> files, but I didnt know how to do that, otherwise I also would have done
> that.
I have built an extension for some other code, and it is high on my list
to get extensions working for pgRouting.
> I personally feel the hassles building  a 64 bit version outweighs the
> pro's but that's just me.
I have gone through the process of building postgis on windows 64 bit
and it is a bit tedious. I'm hoping that we can get this automated in
the future, but we have a lot of other stuff to work on first.
Best regards,
   -Steve
> Pieter
> On Sun, Mar 3, 2013 at 5:51 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     On 3/3/2013 2:49 AM, Pieter du Plooy wrote:
>         Hi guys
>         Those who posted in February about PGRouting and Postgresql 9.2,
>         I have
>         built pgrouting from github against postgresql 9.2 for Windows
>         32 bit.
>         Anyone interested please contact me.
>         Pieter
>     Hi Pieter,
>     Can you send me details on how you did this?
>     I have build PostGIS 2.0 for Windows 64 and I will be doing the same
>     for Windows 32 and also will be pgRouting for both of these. I also
>     hope to get pgRouting to install as an extension under postgresql.
>     My end result is that I want to check in the build and document this
>     process and scripts and check it into git so we have a repeatable
>     process that anyone can replicate for building pgRouting.
>     Thanks,
>        -Steve
>     _________________________________________________
>     Pgrouting-users mailing list
>     Pgrouting-users at lists.osgeo.__org
>     <mailto:Pgrouting-users at lists.osgeo.org>
>     http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
>     <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
More information about the Pgrouting-users mailing list
