[pgrouting-users] Syntax error in sampledata_notopo.sql
maruf rahman
maruf.csdu at gmail.com
Sat Mar 9 06:28:21 PST 2013
Hi
I am trying to install and use pgrouting using the attached document.
Currently I am in step 5.1(Load network data). It says to create a database
and load data in it using the following two commands.
*createdb -U postgres pgrouting-workshop
psql -U postgres -d pgrouting-workshop \
-f ~/Desktop/pgrouting-workshop/data/sampledata_notopo.sql*
The first one goes well. When I execute the second command I get some
errors. Please check here <http://paste.ubuntu.com/5598943/>.
Here<https://docs.google.com/file/d/0B3djwV2dbCYZMk1kZS1mQmdYVTg/edit?usp=sharing>is
the sampledata_notopo.sql file.
How can I solve this problem?
Thanks
Maruf
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130309/21388204/attachment-0001.html>
Type: application/pdf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130309/21388204/attachment-0001.pdf>
More information about the Pgrouting-users
