[pgrouting-users] Syntax error in sampledata_notopo.sql
Daniel Kastl
daniel at georepublic.de
Sat Mar 9 06:46:37 PST 2013
Hi Maruf,
Could be that this version of the workshop is outdated as it's the one from
FOSS4G 2010.
Can you try the workshop FOSS4G 2011 instead?
The most up-to-date content is always the online version:
http://workshop.pgrouting.org/
Daniel
On Sat, Mar 9, 2013 at 11:28 PM, maruf rahman <maruf.csdu at gmail.com> wrote:
> Hi
> I am trying to install and use pgrouting using the attached document.
> Currently I am in step 5.1(Load network data). It says to create a database
> and load data in it using the following two commands.
> *createdb -U postgres pgrouting-workshop
> psql -U postgres -d pgrouting-workshop \
> -f ~/Desktop/pgrouting-workshop/data/sampledata_notopo.sql*
> The first one goes well. When I execute the second command I get some
> errors. Please check here <http://paste.ubuntu.com/5598943/>.
> Here<https://docs.google.com/file/d/0B3djwV2dbCYZMk1kZS1mQmdYVTg/edit?usp=sharing>is the sampledata_notopo.sql file.
> How can I solve this problem?
> Thanks
> Maruf
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130309/9d7f41a1/attachment.html>
More information about the Pgrouting-users
