[pgrouting-users] Syntax error in sampledata_notopo.sql
maruf rahman maruf.csdu at gmail.com
Sat Mar 9 07:18:09 PST 2013
Hi
The problem still occurs. Here is the output<http://paste.ubuntu.com/5599146/>
Previously i replaced all '\N', so it wasn't in error list. Now I have run
the command in original file.
Thanks
Maruf
On Sat, Mar 9, 2013 at 8:46 PM, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Maruf,
> Could be that this version of the workshop is outdated as it's the one
> from FOSS4G 2010.
> Can you try the workshop FOSS4G 2011 instead?
> The most up-to-date content is always the online version:
> http://workshop.pgrouting.org/
> Daniel
> On Sat, Mar 9, 2013 at 11:28 PM, maruf rahman <maruf.csdu at gmail.com>wrote:
>> Hi
>> I am trying to install and use pgrouting using the attached document.
>> Currently I am in step 5.1(Load network data). It says to create a database
>> and load data in it using the following two commands.
>> *createdb -U postgres pgrouting-workshop
>> psql -U postgres -d pgrouting-workshop \
>> -f ~/Desktop/pgrouting-workshop/data/sampledata_notopo.sql*
>> The first one goes well. When I execute the second command I get some
>> errors. Please check here <http://paste.ubuntu.com/5598943/>.
>> Here<https://docs.google.com/file/d/0B3djwV2dbCYZMk1kZS1mQmdYVTg/edit?usp=sharing>is the sampledata_notopo.sql file.
>> How can I solve this problem?
>> Thanks
>> Maruf
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130309/513ca7c3/attachment.html>
More information about the Pgrouting-users mailing list
