[pgrouting-users] Syntax error in sampledata_notopo.sql
maruf rahman
maruf.csdu at gmail.com
Sat Mar 9 07:22:21 PST 2013
Here is the original sampledata_notopo.sql file.
https://docs.google.com/file/d/0B3djwV2dbCYZVV9QVjg3TngzUzg/edit?usp=sharing
On Sat, Mar 9, 2013 at 9:18 PM, maruf rahman <maruf.csdu at gmail.com> wrote:
> Hi
> The problem still occurs. Here is the output<http://paste.ubuntu.com/5599146/>
> Previously i replaced all '\N', so it wasn't in error list. Now I have run
> the command in original file.
> Thanks
> Maruf
> On Sat, Mar 9, 2013 at 8:46 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>> Hi Maruf,
>> Could be that this version of the workshop is outdated as it's the one
>> from FOSS4G 2010.
>> Can you try the workshop FOSS4G 2011 instead?
>> The most up-to-date content is always the online version:
>> http://workshop.pgrouting.org/
>> Daniel
>> On Sat, Mar 9, 2013 at 11:28 PM, maruf rahman <maruf.csdu at gmail.com>wrote:
>>> Hi
>>> I am trying to install and use pgrouting using the attached document.
>>> Currently I am in step 5.1(Load network data). It says to create a database
>>> and load data in it using the following two commands.
>>> *createdb -U postgres pgrouting-workshop
>>> psql -U postgres -d pgrouting-workshop \
>>> -f ~/Desktop/pgrouting-workshop/data/sampledata_notopo.sql*
>>> The first one goes well. When I execute the second command I get some
>>> errors. Please check here <http://paste.ubuntu.com/5598943/>.
>>> Here<https://docs.google.com/file/d/0B3djwV2dbCYZMk1kZS1mQmdYVTg/edit?usp=sharing>is the sampledata_notopo.sql file.
>>> How can I solve this problem?
>>> Thanks
>>> Maruf
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130309/751537bd/attachment.html>
More information about the Pgrouting-users
