[pgrouting-users] postgis 2.0 error find_srid()
Ian Tangert itangert at gmail.com
Fri Mar 15 05:01:07 PDT 2013
hi,
does it work if you change the find_srid() function to st_find_srid() in the assign_vertex_id function()? I had to add st_ to some of the functions inside the pgrouting functions once, but I'm sorry I can't remember now exactly how I built that platform,but it was postgis 2.0,
Ian
-------- Original message --------
Subject: [pgrouting-users] postgis 2.0 error find_srid()
To: pgRouting users mailing list <pgrouting-users at lists.osgeo.org>
CC:
Hi guys,
I'm installed the pgrouting with postgres 9.1.8 and postgis 2 and i have
all my data in a distint schema (not 'public')...
When i run the query to create topology [1] i get an error [2].
I'm already try to run select 'populate_geometry_columns()' and the
table is corectly referenced in geometry_columns.
Can anybody help me with that or a different function of postgis to
create topology?
thanks
[1]
SELECT assign_vertex_id('arcos', .001, 'the_geom', 'id');
[2]
NOTICE:  CREATE TABLE will create implicit sequence
"vertices_tmp_id_seq" for serial column "vertices_tmp.id"
CONTEXT:  SQL statement "CREATE TABLE vertices_tmp (id serial)"
PL/pgSQL function "assign_vertex_id" line 15 at EXECUTE statement
ERROR:  find_srid() - couldnt find the corresponding SRID - is the
geometry registered in the GEOMETRY_COLUMNS table?  Is there an
uppercase/lowercase missmatch?
CONTEXT:  PL/pgSQL function "assign_vertex_id" line 21 at assignment
Pgrouting-users mailing list
Pgrouting-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130315/cdc9e43d/attachment.html>
More information about the Pgrouting-users mailing list
