[pgrouting-users] postgis 2.0 error find_srid()
Pedro Costa
pedrocostaarma at sapo.pt
Fri Mar 15 04:18:29 PDT 2013
Hi guys,
I'm installed the pgrouting with postgres 9.1.8 and postgis 2 and i have
all my data in a distint schema (not 'public')...
When i run the query to create topology [1] i get an error [2].
I'm already try to run select 'populate_geometry_columns()' and the
table is corectly referenced in geometry_columns.
Can anybody help me with that or a different function of postgis to
create topology?
thanks
[1]
SELECT assign_vertex_id('arcos', .001, 'the_geom', 'id');
[2]
NOTICE: CREATE TABLE will create implicit sequence
"vertices_tmp_id_seq" for serial column "vertices_tmp.id"
CONTEXT: SQL statement "CREATE TABLE vertices_tmp (id serial)"
PL/pgSQL function "assign_vertex_id" line 15 at EXECUTE statement
ERROR: find_srid() - couldnt find the corresponding SRID - is the
geometry registered in the GEOMETRY_COLUMNS table? Is there an
uppercase/lowercase missmatch?
CONTEXT: PL/pgSQL function "assign_vertex_id" line 21 at assignment
More information about the Pgrouting-users
