[pgrouting-users] Problem using osm2pgrouting: value too large
Daniel Kastl
daniel at georepublic.de
Mon Mar 18 11:33:11 PDT 2013
Hi Andrew,
osm2pgrouting right now doesn't work with PostGIS 2.0.
Even if you load legacy.sql it will fail because of MULTILINESTRING
geometry type created by the tool.
The source shouldn't be too difficult to fix and make it work with PostGIS
2.0. A pull request would be very welcome, because I currently have no time
to fix and test it.
One alternative would be to use osm2po (osm2po.de), which is fast and
already has fixed the MULTILINESTRING issue.
Daniel
On Tue, Mar 19, 2013 at 2:53 AM, Andrew J Perrin <andrew_perrin at unc.edu>wrote:
> Greetings-
> I have postgis 2.0 installed under postgresql 9.1 on a Debian server. I am
> seeking to use pgRouting for a research task: we will ultimately need to be
> able to locate the three nearest locations (by routing, not geography) in
> our database to a list of addresses we will provide.
> I am working on importing OSM data on North Carolina, which will include
> all the routing information we need. I downloaded the file from
> http://download.geofabrik.de/**north-america/us/north-**
> carolina-latest.osm.bz2<http://download.geofabrik.de/north-america/us/north-carolina-latest.osm.bz2>and uncompressed it.
> I then ran:
> /usr/src/osm2pgrouting-master/**osm2pgrouting -file
> ./north-carolina-latest.osm -conf /usr/src/osm2pgrouting-master/**mapconfig.xml
> -dbname lenoir -user postgres -passwd *******
> The output was:
> host=127.0.0.1 user=postgres dbname=lenoir port=5432 password=*******
> connection success
> Trying to load config file /usr/src/osm2pgrouting-master/**mapconfig.xml
> Trying to parse config
> Trying to load data
> Trying to parse data
> Split ways
> Adding tag types and classes to database...
> Adding relations to database...
> Adding nodes to database...
> SSL error: sslv3 alert unexpected message
> Adding ways to database...
> Creating topology...
> size of streets: 484625
> size of splitted ways : 1080943
> finished
> HOWEVER, no records are in the "ways" or "nodes" tables afterward:
> lenoir=# select count(*) from nodes;
> count
> 0
> (1 row)
> lenoir=# select count(*) from ways;
> count
> 0
> (1 row)
> ...and the postgresql log shows:
> 2013-03-18 13:41:12 EDT ERROR: value "2147643707" is out of range for
> type integer
> 2013-03-18 13:41:12 EDT CONTEXT: COPY nodes, line 31000313, column id:
> "2147643707"
> 2013-03-18 13:41:12 EDT STATEMENT: COPY nodes(id, lon, lat) from STDIN
> 2013-03-18 13:41:13 EDT LOG: SSL renegotiation failure
> 2013-03-18 13:41:13 EDT STATEMENT: COPY nodes(id, lon, lat) from STDIN
> 2013-03-18 13:41:13 EDT LOG: SSL error: unexpected record
> 2013-03-18 13:41:13 EDT LOG: could not send data to client: Connection
> reset by peer
> 2013-03-18 13:41:13 EDT LOG: could not receive data from client:
> Connection reset by peer
> 2013-03-18 13:41:13 EDT LOG: unexpected EOF on client connection
> Thanks for any advice.
> Andrew J Perrin - Associate Professor of Sociology
> University of North Carolina - CB#3210, Chapel Hill, NC 27599-3210 USA
> andrew_perrin at unc.edu - http://perrin.socsci.unc.edu - (919) 962-6876
> ______________________________**_________________
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130319/c960d9f8/attachment.html>
More information about the Pgrouting-users
