[pgrouting-users] Problem using osm2pgrouting: value too large
Andrew J Perrin
andrew_perrin at unc.edu
Mon Mar 18 11:54:22 PDT 2013
Actually I was able to make this work by:
alter table relation_ways alter column relation_id type bigint;
alter table relation_ways alter column way_id type bigint;
alter table nodes alter column id type bigint;
\i '/usr/src/postgis-2.0.1/spatial_ref_sys.sql';
SELECT assign_vertex_id('ways', 0.00001, 'the_geom', 'gid');
...so a shortest_path() query is now working correctly in my dataset.
Now I have to go about figuring out how to apply it to the research
question!
Andy
On 03/18/2013 02:33 PM, Daniel Kastl wrote:
> Hi Andrew,
> osm2pgrouting right now doesn't work with PostGIS 2.0.
> Even if you load legacy.sql it will fail because of MULTILINESTRING
> geometry type created by the tool.
> The source shouldn't be too difficult to fix and make it work with
> PostGIS 2.0. A pull request would be very welcome, because I currently
> have no time to fix and test it.
> One alternative would be to use osm2po (osm2po.de <http://osm2po.de>),
> which is fast and already has fixed the MULTILINESTRING issue.
> Daniel
> On Tue, Mar 19, 2013 at 2:53 AM, Andrew J Perrin <andrew_perrin at unc.edu
> <mailto:andrew_perrin at unc.edu>> wrote:
> Greetings-
> I have postgis 2.0 installed under postgresql 9.1 on a Debian
> server. I am seeking to use pgRouting for a research task: we will
> ultimately need to be able to locate the three nearest locations (by
> routing, not geography) in our database to a list of addresses we
> will provide.
> I am working on importing OSM data on North Carolina, which will
> include all the routing information we need. I downloaded the file
> from
> http://download.geofabrik.de/__north-america/us/north-__carolina-latest.osm.bz2
> <http://download.geofabrik.de/north-america/us/north-carolina-latest.osm.bz2>
> and uncompressed it.
> I then ran:
> /usr/src/osm2pgrouting-master/__osm2pgrouting -file
> ./north-carolina-latest.osm -conf
> /usr/src/osm2pgrouting-master/__mapconfig.xml -dbname lenoir -user
> postgres -passwd *******
> The output was:
> host=127.0.0.1 user=postgres dbname=lenoir port=5432 password=*******
> connection success
> Trying to load config file /usr/src/osm2pgrouting-master/__mapconfig.xml
> Trying to parse config
> Trying to load data
> Trying to parse data
> Split ways
> Adding tag types and classes to database...
> Adding relations to database...
> Adding nodes to database...
> SSL error: sslv3 alert unexpected message
> Adding ways to database...
> Creating topology...
> size of streets: 484625
> size of splitted ways : 1080943
> finished
> HOWEVER, no records are in the "ways" or "nodes" tables afterward:
> lenoir=# select count(*) from nodes;
> count
> 0
> (1 row)
> lenoir=# select count(*) from ways;
> count
> 0
> (1 row)
> ...and the postgresql log shows:
> 2013-03-18 13:41:12 EDT ERROR: value "2147643707" is out of range
> for type integer
> 2013-03-18 13:41:12 EDT CONTEXT: COPY nodes, line 31000313, column
> 2013-03-18 13:41:12 EDT STATEMENT: COPY nodes(id, lon, lat) from STDIN
> 2013-03-18 13:41:13 EDT LOG: SSL renegotiation failure
> 2013-03-18 13:41:13 EDT STATEMENT: COPY nodes(id, lon, lat) from STDIN
> 2013-03-18 13:41:13 EDT LOG: SSL error: unexpected record
> 2013-03-18 13:41:13 EDT LOG: could not send data to client:
> Connection reset by peer
> 2013-03-18 13:41:13 EDT LOG: could not receive data from client:
> 2013-03-18 13:41:13 EDT LOG: unexpected EOF on client connection
> Thanks for any advice.
> ------------------------------__------------------------------__----------
> Andrew J Perrin - Associate Professor of Sociology
> University of North Carolina - CB#3210, Chapel Hill, NC 27599-3210 USA
> andrew_perrin at unc.edu <mailto:andrew_perrin at unc.edu> -
> http://perrin.socsci.unc.edu - (919) 962-6876
> _________________________________________________
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.__org
> <mailto:Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
> <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
andrew_perrin at unc.edu - http://perrin.socsci.unc.edu - (919) 962-6876
More information about the Pgrouting-users
