[pgrouting-users] Pgrouting-users Digest, Vol 54, Issue 23
Tom White tom.white at gmail.com
Tue Mar 26 12:51:22 PDT 2013
On Tue, Mar 26, 2013 at 2:00 PM, <pgrouting-users-request at lists.osgeo.org>wrote:
> > Hello. I'm using pgRouting for traffic congestion analysis. After
> > gathering enough data I'd like to display estimated traffic congestion
> via
> > Google Maps API using pgRouting edges geometries as reference. How can I
> > aggregate pgRouting edges to segments representing larger road sections,
> > eg. between two major intersections?
> You could use ST_Union to aggregate geometries, but you need to be able to
> define where a major intersection is.
> For example you could loop through your result and when there is a change
> of a road name, you would start a new aggregation.
I found that st_collect worked best:
update units set route=(SELECT st_setsrid(ST_LineMerge(
st_collect(ST_AsText(geom_way))),4326) FROM shortest_path_astar
('SELECT id, source::int4, target::int4, reverse_cost, cost,x1, y1,x2, y2
FROM usmr_route order by id',
nn(ST_StartPoint(destination),0.0001,2,100,'usmr_route','source','geom_way')::int4,
nn(ST_EndPoint(destination),0.0001,2,100,'usmr_route','target','geom_way')::int4,
true,true) r join usmr_route o on r.edge_id=o.id) where
unitnumber='(something)'
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130326/5df6dd8d/attachment.html>
More information about the Pgrouting-users mailing list
