[pgrouting-users] Where to get the data for the Workshop?
Daniel Kastl daniel at georepublic.de
Thu Mar 28 08:43:45 PDT 2013
On Fri, Mar 29, 2013 at 12:14 AM, Luís de Sousa
<luis.a.de.sousa at gmail.com>wrote:
> Hello everyone,
> I'm just starting with pgRouting, following the workshop tutorial
> available on line. I've installed all the required packages and
> created the databases successfully, but unfortunately I'm not able to
> get the data. Here's the result using the command in the workshop
> pages:
> $ wget --progress=dot:mega -O "sampledata.osm"
> http://jxapi.openstreetmap.org/xapi/api/0.6/*[bbox=-105.2147,39.5506,-104.594,39.9139]
> Warning: wildcards not supported in HTTP.
> --2013-03-28 15:37:59--
> Resolving jxapi.openstreetmap.org (jxapi.openstreetmap.org)...
> 128.40.168.100
> Connecting to jxapi.openstreetmap.org
> (jxapi.openstreetmap.org)|128.40.168.100|:80... connected.
> HTTP request sent, awaiting response... 502 Proxy Error
> 2013-03-28 15:52:59 ERROR 502: Proxy Error.
> In face of this I went to the OSM wiki to check if this address was
> correct. I thus tried it the way they suggest there:
> http://api.openstreetmap.org/api/0.6/map?bbox=-105.2147,39.5506,-104.594,39.9139
> --2013-03-28 15:55:01--
> Resolving api.openstreetmap.org (api.openstreetmap.org)...
> 193.63.75.99, 193.63.75.100, 193.63.75.103, ...
> Connecting to api.openstreetmap.org
> (api.openstreetmap.org)|193.63.75.99|:80... connected.
> HTTP request sent, awaiting response... 400 Bad Request
> 2013-03-28 15:55:01 ERROR 400: Bad Request.
> Still no luck, so I tried with JOSM, as suggested in the workshop
> page. Using the same bounding box I get this error:
> The OSM server 'http://api.openstreetmap.org/api/0.6/' reported a bad
> request.
> The area you tried to download is too big or your request was too large.
> Either request a smaller area or use an export file provided by the
> OSM community
> Apparently the API is not digesting well this bounding box. Is there
> any other way I could get the data to follow on with the Workshop?
Eventually the API has changed (the current workshop was mainly written for
FOSS4G 2011).
There are various ways though to download OSM data, ie:
http://download.geofabrik.de/
http://download.bbbike.org/osm/
http://developer.mapquest.com/web/products/open/xapi
So I'm not sure the current API error is temporary. Could be that the XAPI
is not available anymore:
http://wiki.openstreetmap.org/wiki/Xapi
If you find a working solution I'm glad to update the workshop.
Daniel
> Thank you,
> Luís
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130329/f3e023f8/attachment.html>
More information about the Pgrouting-users mailing list
