[pgrouting-users] Optimize routing - use new sew-devel-2_0 functions
Tao Romera Martinez taoromera at gmail.com
Wed May 22 03:55:53 PDT 2013
Oh, then use a bounding box. It will improve the speed of the query a lot.
Something like this:
SELECT * FROM shortest_path('
                SELECT gid as id,
                         source::integer,
                         target::integer,
                         length::double precision as cost
                        FROM japan WHERE japan.geom_way &&
ST_MakeEnvelope(139.675, 35.729, 139.705, 35.762);',
                5700, 6733, false, false);
Don't forget to create an index in the geom column:
CREATE INDEX my_idx ON japan USING GIST(geom);
Tao
2013/5/22 Tao Romera Martinez <taoromera at gmail.com>:
> Frederic,
> The time to generate a route is mostly spent in retrieving the ways
> from the DB and passing them to the C function that performs the
> Dikstra, as Stephen once pointed out in a private mail to me. With a
> small graph, 80% of the time consumed by shortest_path goes to
> retrieving the ways.
> If you really need to improve the efficiency of 1 search in your
> service, you could consider modifying the C code to reuse the ways
> retrieved from the DB and generate a new route with different
> parameters.
> Tao
> 2013/5/22 Daniel Kastl <daniel at georepublic.de>:
>> On Wed, May 22, 2013 at 6:42 PM, Frédéric Bonifas
>> <fredericbonifas at gmail.com> wrote:
>>> I agree the the routes will be relatively short for pedestrian routing,
>>> but :
>>> * if I understand correctly how Dijkstra works, the routing time will
>>> mostly depend on the size of the graph, as the whole graph will be
>>> visited before giving the shortest_route.
>>> * the fastest it is, the more I like it :)
>>> * I show to the user different possible routes (4) so the routing time
>>> is multiplied by this factor.
>> Hi Frederic,
>> The algorithm doesn't make such  big difference as you might expect.
>> What matters is the size of the network that you load for a routing request,
>> which depends on the length of the route and the road density.
>> For example a 40km route through Tokyo will load a huge amount of data, but
>> some sparse area in Canada 40km would not be an issue.
>> For your pedestrian routing, did you make sure that you don't load the whole
>> network table for every request?
>> The easiest way to limit the data you select is using a BBOX.
>>  Daniel
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: http://georepublic.de
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Tao Romera Martínez
> Tel: 080-6805-0945
> Address: Koganei-shi, Tokyo, Japan
> Look for me on Facebook and LinkedIn
Tao Romera Martínez
Tel: 080-6805-0945
More information about the Pgrouting-users mailing list
