[pgrouting-users] Optimize routing - use new sew-devel-2_0 functions
Stephen Woodbridge
woodbri at swoodbridge.com
Wed May 22 08:25:30 PDT 2013
Basically the wrappers all did variations of the following pattern:
1. take the XY of the start and end point of the route
2. find the nearest edge or vertex to those points
3. compute a BBOX like the following
japan.geom_way && ST_EXPAND(
ST_SetSRID(
ST_MakeLine(
ST_MakePoint(start_x, start_y),
ST_MakePoint(end_x, end_y)
4326), -- set the SRID
0.05) -- expand by this in SRID
4. run one of the shortest path queries.
Regarding which query to run:
Regardless of restrictions, the pgr_trsp() is a good function to use,
because you and pass it and edge and a percent along the edge for bot
the start and end points.
Then try algorithms in this order if performance is you goal:
pgr_bdastar - currently has a bug that we hope to fix before release
pgr_astar
pgr_bddijkstra - currently has bug
pgr_dijkstra
Hope this helps,
-Steve
On 5/22/2013 6:55 AM, Tao Romera Martinez wrote:
> Oh, then use a bounding box. It will improve the speed of the query a lot.
> Something like this:
> SELECT * FROM shortest_path('
> SELECT gid as id,
> source::integer,
> target::integer,
> length::double precision as cost
> FROM japan WHERE japan.geom_way &&
> ST_MakeEnvelope(139.675, 35.729, 139.705, 35.762);',
> 5700, 6733, false, false);
> Don't forget to create an index in the geom column:
> CREATE INDEX my_idx ON japan USING GIST(geom);
> Tao
> 2013/5/22 Tao Romera Martinez <taoromera at gmail.com>:
>> Frederic,
>> The time to generate a route is mostly spent in retrieving the ways
>> from the DB and passing them to the C function that performs the
>> Dikstra, as Stephen once pointed out in a private mail to me. With a
>> small graph, 80% of the time consumed by shortest_path goes to
>> retrieving the ways.
>> If you really need to improve the efficiency of 1 search in your
>> service, you could consider modifying the C code to reuse the ways
>> retrieved from the DB and generate a new route with different
>> parameters.
>> Tao
>> 2013/5/22 Daniel Kastl <daniel at georepublic.de>:
>>> On Wed, May 22, 2013 at 6:42 PM, Frédéric Bonifas
>>> <fredericbonifas at gmail.com> wrote:
>>>> I agree the the routes will be relatively short for pedestrian routing,
>>>> but :
>>>> * if I understand correctly how Dijkstra works, the routing time will
>>>> mostly depend on the size of the graph, as the whole graph will be
>>>> visited before giving the shortest_route.
>>>> * the fastest it is, the more I like it :)
>>>> * I show to the user different possible routes (4) so the routing time
>>>> is multiplied by this factor.
>>> Hi Frederic,
>>> The algorithm doesn't make such big difference as you might expect.
>>> What matters is the size of the network that you load for a routing request,
>>> which depends on the length of the route and the road density.
>>> For example a 40km route through Tokyo will load a huge amount of data, but
>>> some sparse area in Canada 40km would not be an issue.
>>> For your pedestrian routing, did you make sure that you don't load the whole
>>> network table for every request?
>>> The easiest way to limit the data you select is using a BBOX.
>>> Daniel
>>> Georepublic UG & Georepublic Japan
>>> eMail: daniel.kastl at georepublic.de
>>> Web: http://georepublic.de
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>> Tao Romera Martínez
>> Tel: 080-6805-0945
>> Address: Koganei-shi, Tokyo, Japan
>> Look for me on Facebook and LinkedIn
More information about the Pgrouting-users
