[pgrouting-users] sew-devel-2_0 build problems
Dave Potts
dave.potts at pinan.co.uk
Sat May 25 10:48:01 PDT 2013
On 25/05/13 18:33, Stephen Woodbridge wrote:
Hi Steve,
Thanks for the prompt help, in the end I hacked the makefile and did a
normal make and compile a version.
I did try your build instructions
ie tools/doit and got an error about (missing: SPHINX_EXECUTABLE)
I am using cmake version 2.8.11
Dave.
tools/doit
-- UNIX=1
-- WIN32=
-- POSTGRESQL_EXECUTABLE is /usr/lib/postgresql/9.1/bin/postgres
-- POSTGRESQL_PG_CONFIG is /usr/bin/pg_config
-- POSTGRESQL_INCLUDE_DIR: /usr/include/postgresql/9.1/server
-- POSTGRESQL_LIBRARIES: /usr/lib
-- Boost version: 1.48.0
Boost headers were found here: /usr/include
-- POSTGRESQL_VERSION_STRING is PostgreSQL 9.1.9
-- POSTGRESQL_VERSION is 9.1.9
-- Install directory for libraries is set to /usr/lib/postgresql/9.1/lib
-- Install directory for SQL files is set to
/usr/share/postgresql/9.1/extension
CMake Error at
/usr/local/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:108
(message):
DEFAULT_MSG
Call Stack (most recent call first):
/usr/local/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:315
(_FPHSA_FAILURE_MESSAGE)
cmake/FindSphinx.cmake:16 (find_package_handle_standard_args)
doc/CMakeLists.txt:14 (find_package)
-- Configuring incomplete, errors occurred!
make: *** No targets specified and no makefile found. Stop.
> Sorry, Daniel posted the URL for those that have write privledges to
> the the repository. You can use the public one
> git://github.com/pgRouting/pgrouting.git
> or you can fork the repository if you have your won github account and
> make changes there and generate pull requests for us to pull your
> changes into the master respository.
> https://github.com/pgRouting/pgrouting/tree/sew-devel-2_0
> Notice the HTTP, SSH, Git Reead-Only buttons, by clicking on them you
> can see the different URLS that can be used.
> git clone git://github.com/pgRouting/pgrouting.git
> git checkout sew-devel-2_0
> tools/doit
> (cd build; sudo make install)
> tools/test-runner.pl
> is the standard way I build and test on Linux.
> -Steve
> On 5/25/2013 1:01 PM, Dave Potts wrote:
>> On 25/05/13 14:21, Stephen Woodbridge wrote:
>> hi
>> I tried Daniel suggestion ie
>> git clone git at github.com:pgRouting/pgrouting.git
>> and got
>> Cloning into 'pgrouting'...
>> Permission denied (publickey).
>> fatal: The remote end hung up unexpectedly
>> not the error I was expecting :-(
>> D.
>>> Hi Dave,
>>> We don't test in the tarball environment. May be you can figure out
>>> the cmake stuff there. What is supposed to happen,
>>> check if git exists or not (non fatal)
>>> if git exists then
>>> if git repository get git hash
>>> else report non fatal message
>>> else
>>> report non-fatal message
>>> This is all done in this block:
>>> # Find Git to collect version information
>>> find_package(Git QUIET)
>>> if(GIT_FOUND)
>>> message(STATUS "Found Git: ${GIT_EXECUTABLE}")
>>> GIT_WC_INFO(${PGROUTING_SOURCE_DIR} PGROUTING)
>>> set(PGROUTING_VERSION_REVISION_NAME "${PGROUTING_WC_REVISION_NAME}")
>>> set(PGROUTING_VERSION_REVISION_HASH "${PGROUTING_WC_REVISION_HASH}")
>>> else()
>>> message(STATUS "Could NOT find GIT (optional)")
>>> set(PGROUTING_VERSION_REVISION_NAME "")
>>> set(PGROUTING_VERSION_REVISION_HASH "")
>>> endif()
>>> my guess is you have git and GIT_WC_INFO is fatal for not a repository.
>>> The quick fix so you can continue is to replace the block above with
>>> -Steve
>>> On 5/25/2013 8:53 AM, Dave Potts wrote:
>>>> On 25/05/13 11:41, Daniel Kastl wrote:
>>>>> On Sat, May 25, 2013 at 6:11 PM, Dave Potts <dave.potts at pinan.co.uk
>>>>> <mailto:dave.potts at pinan.co.uk>> wrote:
>>>>> Hi list
>>>>> I want a play from the new version of the tsp code.
>>>>> I have tried building it on Ubuntu 3.2.0-43-generic #68-Ubuntu
>>>>> SMP with postgres 9.1.9 using the syntax
>>>>> cmake DebugFull .
>>>>> I got the following errors[See Below]
>>>>> Q. What should the build envronment be pgroute 2.0??
>>>>> Hi Dave,
>>>>> There seems to be a problem with the use of the Git module of CMake.
>>>>> The check for Git is not something that must be included, but it's
>>>>> convenient, because it allows to place the version information for
>>>>> example in the documentation or some time into a function to retreive
>>>>> the pgRouting version.
>>>>> I have tested, that it works when you build from a Git repository
>>>>> with
>>>>> Git installed.
>>>>> And I think I have tested the case when Git is not installed and it's
>>>>> not a Git repository.
>>>>> In your case, do you build from a cloned repository?
>>>>> I have already upgraded my version of cmake 2.8.11
>>>>> The required version is checked and it will give an error when your
>>>>> version is not new enough.
>>>>> These are a few commands I'm using to build on Ubuntu:
>>>>> https://gist.github.com/dkastl/5617030
>>>> Hi DAniel,
>>>> WIll check out these tools, which version off Ubuntu are you on?
>>>> I did'nt clone a copy, I just got it out as a zip file.
>>>> Dave.
>>>>> Daniel
>>>>> regards
>>>>> Dave.
>>>>> src/pgroute/pgr2.0/pgrouting-sew-devel-2_0 failed with output:
>>>>> fatal: Not a git repository (or any parent up to mount parent )
>>>>> Stopping at filesystem boundary
>>>>> (GIT_DISCOVERY_ACROSS_FILESYSTEM
>>>>> not set).
>>>>> CMakeLists.txt:68 (GIT_WC_INFO)
>>>>> CMake Warning at cmake/FindGit.cmake:144 (message):
>>>>> No remote origin set for git repository:
>>>>> /home/dp42/src/pgroute/pgr2.0/pgrouting-sew-devel-2_0
>>>>> -- LIBS_TO_INSTALL=
>>>>> _______________________________________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.org
>>>>> <mailto:Pgrouting-users at lists.osgeo.org>
>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>>> Georepublic UG & Georepublic Japan
>>>>> eMail: daniel.kastl at georepublic.de
>>>>> <mailto:daniel.kastl at georepublic.de>
>>>>> Web: http://georepublic.de <http://georepublic.de/>
More information about the Pgrouting-users
