[pgrouting-users] sew-devel-2_0 build problems
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Sat May 25 10:52:59 PDT 2013
Hi Dave,
tools/doit is a trivial script:
#!/bin/sh
rm -rf build
mkdir build
cd build
cmake -DWITH_DOC=ON -DWITH_DD=ON ..
make
The sphinx error can be worked around by removing -DWITH_DOC=ON from the
cmake line.
I just made the script because I have to run it a million times a day
when I'm changing stuff and merging code.
-Steve
On 5/25/2013 1:48 PM, Dave Potts wrote:
> On 25/05/13 18:33, Stephen Woodbridge wrote:
> Hi Steve,
> Thanks for the prompt help,  in the end I hacked the makefile and did a
> normal make and compile a version.
> I did try your build instructions
> ie tools/doit  and got an error about    (missing: SPHINX_EXECUTABLE)
> I am using cmake version 2.8.11
> Dave.
>   tools/doit
> -- UNIX=1
> -- WIN32=
> -- POSTGRESQL_EXECUTABLE is /usr/lib/postgresql/9.1/bin/postgres
> -- POSTGRESQL_PG_CONFIG is /usr/bin/pg_config
> -- POSTGRESQL_INCLUDE_DIR: /usr/include/postgresql/9.1/server
> -- POSTGRESQL_LIBRARIES: /usr/lib
> -- Boost version: 1.48.0
> Boost headers were found here: /usr/include
> -- POSTGRESQL_VERSION_STRING is PostgreSQL 9.1.9
> -- POSTGRESQL_VERSION is 9.1.9
> -- Install directory for libraries is set to /usr/lib/postgresql/9.1/lib
> -- Install directory for SQL files is set to
> /usr/share/postgresql/9.1/extension
> CMake Error at
> /usr/local/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:108
> (message):
>    DEFAULT_MSG
> Call Stack (most recent call first):
> /usr/local/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:315
> (_FPHSA_FAILURE_MESSAGE)
>    cmake/FindSphinx.cmake:16 (find_package_handle_standard_args)
>    doc/CMakeLists.txt:14 (find_package)
> -- Configuring incomplete, errors occurred!
> make: *** No targets specified and no makefile found. Stop.
>> Sorry, Daniel posted the URL for those that have write privledges to
>> the the repository. You can use the public one
>> git://github.com/pgRouting/pgrouting.git
>> or you can fork the repository if you have your won github account and
>> make changes there and generate pull requests for us to pull your
>> changes into the master respository.
>> https://github.com/pgRouting/pgrouting/tree/sew-devel-2_0
>> Notice the HTTP, SSH, Git Reead-Only buttons, by clicking on them you
>> can see the different URLS that can be used.
>> git clone git://github.com/pgRouting/pgrouting.git
>> git checkout sew-devel-2_0
>> tools/doit
>> (cd build; sudo make install)
>> tools/test-runner.pl
>> is the standard way I build and test on Linux.
>> -Steve
>> On 5/25/2013 1:01 PM, Dave Potts wrote:
>>> On 25/05/13 14:21, Stephen Woodbridge wrote:
>>> hi
>>> I tried Daniel suggestion ie
>>> git clone git at github.com:pgRouting/pgrouting.git
>>> and got
>>> Cloning into 'pgrouting'...
>>> Permission denied (publickey).
>>> fatal: The remote end hung up unexpectedly
>>> not the error I was expecting :-(
>>> D.
>>>> Hi Dave,
>>>> We don't test in the tarball environment. May be you can figure out
>>>> the cmake stuff there. What is supposed to happen,
>>>> check if git exists or not (non fatal)
>>>> if git exists then
>>>>   if git repository get git hash
>>>>   else report non fatal message
>>>> else
>>>>   report non-fatal message
>>>> This is all done in this block:
>>>> # Find Git to collect version information
>>>> find_package(Git QUIET)
>>>> if(GIT_FOUND)
>>>>   message(STATUS "Found Git: ${GIT_EXECUTABLE}")
>>>>   GIT_WC_INFO(${PGROUTING_SOURCE_DIR} PGROUTING)
>>>>   set(PGROUTING_VERSION_REVISION_NAME "${PGROUTING_WC_REVISION_NAME}")
>>>>   set(PGROUTING_VERSION_REVISION_HASH "${PGROUTING_WC_REVISION_HASH}")
>>>> else()
>>>>   message(STATUS "Could NOT find GIT (optional)")
>>>>   set(PGROUTING_VERSION_REVISION_NAME "")
>>>>   set(PGROUTING_VERSION_REVISION_HASH "")
>>>> endif()
>>>> my guess is you have git and GIT_WC_INFO is fatal for not a repository.
>>>> The quick fix so you can continue is to replace the block above with
>>>> -Steve
>>>> On 5/25/2013 8:53 AM, Dave Potts wrote:
>>>>> On 25/05/13 11:41, Daniel Kastl wrote:
>>>>>> On Sat, May 25, 2013 at 6:11 PM, Dave Potts <dave.potts at pinan.co.uk
>>>>>> <mailto:dave.potts at pinan.co.uk>> wrote:
>>>>>>     Hi list
>>>>>>     I want a play from the new version of the tsp code.
>>>>>>     I have tried building it on Ubuntu  3.2.0-43-generic #68-Ubuntu
>>>>>>     SMP with postgres 9.1.9 using the syntax
>>>>>>     cmake DebugFull .
>>>>>>     I got the following errors[See Below]
>>>>>>     Q. What should the build envronment be pgroute 2.0??
>>>>>> Hi Dave,
>>>>>> There seems to be a problem with the use of the Git module of CMake.
>>>>>> The check for Git is not something that must be included, but it's
>>>>>> convenient, because it allows to place the version information for
>>>>>> example in the documentation or some time into a function to retreive
>>>>>> the pgRouting version.
>>>>>> I have tested, that it works when you build from a Git repository
>>>>>> with
>>>>>> Git installed.
>>>>>> And I think I have tested the case when Git is not installed and it's
>>>>>> not a Git repository.
>>>>>> In your case, do you build from a cloned repository?
>>>>>>     I have already upgraded my version of cmake 2.8.11
>>>>>> The required version is checked and it will give an error when your
>>>>>> version is not new enough.
>>>>>> These are a few commands I'm using to build on Ubuntu:
>>>>>> https://gist.github.com/dkastl/5617030
>>>>> Hi DAniel,
>>>>> WIll check out these tools, which version off Ubuntu are you on?
>>>>> I did'nt clone a copy,  I just got it out as a zip file.
>>>>> Dave.
>>>>>> Daniel
>>>>>>     regards
>>>>>>     Dave.
>>>>>>     src/pgroute/pgr2.0/pgrouting-sew-devel-2_0 failed with output:
>>>>>>       fatal: Not a git repository (or any parent up to mount parent )
>>>>>>       Stopping at filesystem boundary
>>>>>> (GIT_DISCOVERY_ACROSS_FILESYSTEM
>>>>>>     not set).
>>>>>>       CMakeLists.txt:68 (GIT_WC_INFO)
>>>>>>     CMake Warning at cmake/FindGit.cmake:144 (message):
>>>>>>       No remote origin set for git repository:
>>>>>> /home/dp42/src/pgroute/pgr2.0/pgrouting-sew-devel-2_0
>>>>>>     -- LIBS_TO_INSTALL=
>>>>>>     _______________________________________________
>>>>>>     Pgrouting-users mailing list
>>>>>>     Pgrouting-users at lists.osgeo.org
>>>>>>     <mailto:Pgrouting-users at lists.osgeo.org>
>>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>>>> Georepublic UG & Georepublic Japan
>>>>>> eMail: daniel.kastl at georepublic.de
>>>>>> <mailto:daniel.kastl at georepublic.de>
>>>>>> Web: http://georepublic.de <http://georepublic.de/>
More information about the Pgrouting-users
