[pgrouting-users] PGRoting Workshop step 4.2 can't create vertices_tmp , vertices_tmp_id_seq
Sithila Konara sithilamadushanka at gmail.com
Fri May 31 22:16:59 PDT 2013
I'm following pgrouing workshop. I followed steps as they said I executed
the command
osm2pgrouting -file "data/sampledata.osm" \
                          -conf "/usr/share/osm2pgrouting/mapconfig.xml" \
                          -dbname routing \
                          -user postgres \
                          -clean
and check the database using
psql -U postgres -d routing -c "\d"
but create  vertices_tmp , vertices_tmp_id_seq tables not created...
How do I do create this tables ?
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130601/bacf27d5/attachment.html>
More information about the Pgrouting-users mailing list
