[pgrouting-users] Questions on osm2pgrouting
    Stephen V. Mather
    svm at clevelandmetroparks.com
    Fri Nov 29 20:18:03 PST 2013
I can only answer one of these questions (and indirectly):
You can move your data.  You can also ensure it goes into the correct schema by default by setting your role's search path
ALTER ROLE postgres SET search_path TO myschema,public;
Best,
Steve
  Stephen V. Mather
GIS Manager
(216) 635-3243 (Work)
________________________________________
From: pgrouting-users-bounces at lists.osgeo.org <pgrouting-users-bounces at lists.osgeo.org> on behalf of Luís de Sousa <luis.a.de.sousa at gmail.com>
Sent: Thursday, November 28, 2013 5:58 AM
To: pgrouting-users at lists.osgeo.org
Subject: [pgrouting-users] Questions on osm2pgrouting
Dear all,
I've been importing large OSM datasets with osm2pgrouting. The tool works
quite well, but I have a few doubts:
. *What is the ways_vertices_pgr_id_seq used for?* I ask this because I need
to move the tables create by osm2pgrouting into their own schema.
. *Why aren't there any foreign keys?* I can see there are a number of
columns that make reference to other tables but no formal constraints are
created. Is this a bug?
. *Why isn't reverse cost equal to length for all rows?* Every time I import
an OSM dataset I have to run an UPDATE query with 'reverse_cost = length',
usually this is not the case for about 10% of the rows.
Thank you,
Luís
View this message in context: http://pgrouting-users.974093.n3.nabble.com/Questions-on-osm2pgrouting-tp4025397.html
Sent from the pgRouting-users mailing list archive at Nabble.com.
Pgrouting-users mailing list
Pgrouting-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
