[pgrouting-users] pgrouting2 and turn restrictions
Yaron Lev yaron666 at gmail.com
Fri Oct 25 11:54:27 PDT 2013
thanks, that was helpful as always
i will try to share the code to "fix" the graph, should i have enough time
to implement this.
thanks.
On Fri, Oct 25, 2013 at 5:26 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 10/22/2013 4:50 AM, Yaron Lev wrote:
>> Hi,
>> I have a small question.
>> Most of the algos do not take turn restrictions into account.
> Yes this is correct. Only the TRSP code handles turn restrictions.
>  If wanted to use for example pgr_ksp (k-shortest path) for example, then
>> that algo will not take turn restrictions into account.
> It might be feasible to implement the KSP algorithm on top of TRSP.
> https://github.com/pgRouting/**pgrouting/issues/206<https://github.com/pgRouting/pgrouting/issues/206>
> If you are interested in developing something and submitting a pull
> request or funding this it would be a great contribution. Or if you have
> funding, we can look at getting getting something developed.
>  The only way i could think about making the algo's work, is to rewire
>> the graph table, so that nodes with turn restrictions, will be removed
>> and instead adding longer edges instead to cover all the travel options.
>> (for each edge, that contains the node in question, append and rewire,
>> its a bit complicated but you should get the idea from my very limited
>> description)
> Yes, when I researched ways to solve turn restriction, I did find articles
> about how it is possible to reconstruct a graph around turn restrictions by
> removing and adding edges to make a "regular" graph that would generate the
> equivalent of the turn restricted routes. But it seemed very complicated.
>  My question is, is there such a tool which extends the graph table as
>> produced by either osm2po or osm2pgrouting for turn restrictions?
> Not that I know of. I think the OSM routing engine does support turn
> restrictions, but it is not part of pgRouting.
>  Is there a different solution i am missing?
> Sorry not that I know of. This is a good suggestion.
> Regards,
>   -Steve
>  Thanks for your help!
>> ______________________________**_________________
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20131025/e2ff64a1/attachment.html>
More information about the Pgrouting-users mailing list
