[pgrouting-users] pgr_drivingdistance (loop)
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Sep 27 06:10:04 PDT 2013
Hi Carla,
It would be useful if you posted what your error message is.
I suspect the the following lines:
> SELECT id1 as no, cost as cost' || i ||
> ' FROM pgr_drivingdistance('
needs to get changed to:
> SELECT id1 as no, cost as cost,' || i || '::integer
-Steve W
On 9/27/2013 5:59 AM, Carla Rebelo wrote:
> Dear all,
> I need to calculate the catchment area for a number of nodes (schools).
> I'm using pgr_driving distance and adding geometry from the nodes table.
> My code creates a table for each destination. Example (for node 71197):
> drop table if exists contagio71197;
> create table contagio71197 as
> SELECT foo.id1 as no, foo.cost as cost71197, vertices_tmp.the_geom
> FROM vertices_tmp inner join pgr_drivingdistance('
> SELECT gid AS id,
> source,
> target,
> tempo::float8 AS cost
> FROM lisboa',
> 71197,
> 20,
> false,
> false) as foo
> on (vertices_tmp.id <http://vertices_tmp.id> = foo.id1);
> Now, since I have around 100 destinations, I tried to loop through the
> list of nodes.
> I wrote the following code (column numero.nn contains the list of nodes
> which constitute the destinations:
> DO $$
> DECLARE
> i integer;
> BEGIN
> FOR i IN (select nn from numero)
> LOOP
> EXECUTE
> 'create table contagio' || i || ' as
> SELECT gid AS id,
> source,
> target,
> FROM lisboa', '
> || i || ' ,
> 30,
> false,
> false)'
> END LOOP;
> END;
> Now, I know where the problem is: the query string after EXECUTE has a
> function that uses another query string as an input
> (pgr_drivingDistance(text sql, ......)
> Probably there's a simple solution, but I can't get it.
> Any help.
> Thank you very much.
> Carla
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
