[pgrouting-users] pgr_drivingdistance (loop)
Carla Rebelo
crrebelo at gmail.com
Fri Sep 27 08:08:01 PDT 2013
Hi Stephen,
Thanks for your reply.
Sorry for the incomplete information...
Running que code:
DO $$
DECLARE
i integer;
BEGIN
FOR i IN (select nn from numero)
LOOP
EXECUTE
'create table contagio' || i || ' as
SELECT id1 as no, cost as cost' || i ||
' FROM pgr_drivingdistance('
SELECT gid AS id,
source,
target,
tempo::float8 AS cost
FROM lisboa',
18 ,
30,
false,
false)'
return the error:
ERROR: syntax error at or near "SELECT"
LINE 11: SELECT gid AS id,
I think I understand what's wrong. I have a query string inside a query
string.
I tried to solve this using $$, but it doesn't work.
If I run:
SELECT *
FROM pgr_drivingdistance($$
SELECT gid AS id,
source,
target,
FROM lisboa$$,
18 ,
30,
false,
false);
It works fine. But if this code comes after EXECUTE as a query string, it
doesn't work (a query string inside a query string)...
Thanks fro any help,
Carla
ubuntu 12.04
postgis version:
"2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
pgrouting version:
"(2.0.0-rc1,v2.0.0-beta,50,6a63bc1,develop,1.46.1)"
END LOOP;
END;
return the error:
string.
If I run:
SELECT *
SELECT gid AS id,
source,
target,
FROM lisboa$$,
18 ,
30,
false,
false);
Carla
ubuntu 12.04
postgis version:
pgrouting version:
2013/9/27 Stephen Woodbridge <woodbri at swoodbridge.com>
> Hi Carla,
> It would be useful if you posted what your error message is.
> I suspect the the following lines:
> needs to get changed to:
> > SELECT id1 as no, cost as cost,' || i || '::integer
> -Steve W
> On 9/27/2013 5:59 AM, Carla Rebelo wrote:
>> Dear all,
>> I need to calculate the catchment area for a number of nodes (schools).
>> I'm using pgr_driving distance and adding geometry from the nodes table.
>> My code creates a table for each destination. Example (for node 71197):
>> drop table if exists contagio71197;
>> create table contagio71197 as
>> SELECT foo.id1 as no, foo.cost as cost71197, vertices_tmp.the_geom
>> FROM vertices_tmp inner join pgr_drivingdistance('
>> SELECT gid AS id,
>> source,
>> target,
>> FROM lisboa',
>> 71197,
>> 20,
>> false,
>> false) as foo
>> on (vertices_tmp.id <http://vertices_tmp.id> = foo.id1);
>> Now, since I have around 100 destinations, I tried to loop through the
>> list of nodes.
>> I wrote the following code (column numero.nn contains the list of nodes
>> which constitute the destinations:
>> DO $$
>> DECLARE
>> i integer;
>> BEGIN
>> LOOP
>> EXECUTE
>> SELECT gid AS id,
>> source,
>> target,
>> FROM lisboa', '
>> || i || ' ,
>> 30,
>> false,
>> false)'
>> END LOOP;
>> END;
>> Now, I know where the problem is: the query string after EXECUTE has a
>> function that uses another query string as an input
>> (pgr_drivingDistance(text sql, ......)
>> Probably there's a simple solution, but I can't get it.
>> Any help.
>> Thank you very much.
>> Carla
>> ______________________________**_________________
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130927/9a699bd0/attachment.html>
More information about the Pgrouting-users
