[pgrouting-users] pgr_drivingdistance (loop)
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Sep 27 08:41:26 PDT 2013
In a quoted string like 'string with '' in it' you have to double the
quote marks for the embedded quote.
DO $$
DECLARE
i integer;
BEGIN
FOR i IN (select nn from numero)
LOOP
EXECUTE
'create table contagio' || i || ' as
SELECT id1 as no, cost as cost' || i ||
' FROM pgr_drivingdistance(''
SELECT gid AS id,
source,
target,
tempo::float8 AS cost
FROM lisboa'',
18 ,
30,
false,
false)'
On 9/27/2013 11:08 AM, Carla Rebelo wrote:
> Hi Stephen,
> Thanks for your reply.
> Sorry for the incomplete information...
> Running que code:
> DO $$
> DECLARE
> i integer;
> BEGIN
> LOOP
> EXECUTE
> SELECT gid AS id,
> source,
> target,
> FROM lisboa',
> 18 ,
> 30,
> false,
> false)'
> return the error:
> ERROR: syntax error at or near "SELECT"
> LINE 11: SELECT gid AS id,
> I think I understand what's wrong. I have a query string inside a query
> string.
> I tried to solve this using $$, but it doesn't work.
> If I run:
> SELECT *
> FROM pgr_drivingdistance($$
> SELECT gid AS id,
> source,
> target,
> FROM lisboa$$,
> 18 ,
> 30,
> false,
> false);
> It works fine. But if this code comes after EXECUTE as a query string,
> it doesn't work (a query string inside a query string)...
> Thanks fro any help,
> Carla
> ubuntu 12.04
> postgis version:
> "2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
> pgrouting version:
> "(2.0.0-rc1,v2.0.0-beta,50,6a63bc1,develop,1.46.1)"
> END LOOP;
> END;
> return the error:
> string.
> If I run:
> SELECT *
> SELECT gid AS id,
> source,
> target,
> FROM lisboa$$,
> 18 ,
> 30,
> false,
> false);
> Carla
> ubuntu 12.04
> postgis version:
> pgrouting version:
> 2013/9/27 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>
> Hi Carla,
> It would be useful if you posted what your error message is.
> I suspect the the following lines:
> needs to get changed to:
> > SELECT id1 as no, cost as cost,' || i || '::integer
> -Steve W
> On 9/27/2013 5:59 AM, Carla Rebelo wrote:
> Dear all,
> I need to calculate the catchment area for a number of nodes
> (schools).
> I'm using pgr_driving distance and adding geometry from the
> nodes table.
> My code creates a table for each destination. Example (for node
> 71197):
> drop table if exists contagio71197;
> create table contagio71197 as
> SELECT foo.id1 as no, foo.cost as cost71197, vertices_tmp.the_geom
> FROM vertices_tmp inner join pgr_drivingdistance('
> SELECT gid AS id,
> source,
> target,
> FROM lisboa',
> 71197,
> 20,
> false,
> false) as foo
> on (vertices_tmp.id <http://vertices_tmp.id>
> <http://vertices_tmp.id> = foo.id1);
> ------------------------------__---
> Now, since I have around 100 destinations, I tried to loop
> through the
> list of nodes.
> I wrote the following code (column numero.nn contains the list
> of nodes
> which constitute the destinations:
> DO $$
> DECLARE
> i integer;
> BEGIN
> LOOP
> EXECUTE
> SELECT gid AS id,
> source,
> target,
> FROM lisboa', '
> || i || ' ,
> 30,
> false,
> false)'
> END LOOP;
> END;
> ------------------------------__------------------------------__---------------
> Now, I know where the problem is: the query string after EXECUTE
> has a
> function that uses another query string as an input
> (pgr_drivingDistance(text sql, ......)
> Probably there's a simple solution, but I can't get it.
> Any help.
> Thank you very much.
> Carla
> _________________________________________________
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.__org
> <mailto:Pgrouting-users at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
> <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
More information about the Pgrouting-users
