[pgrouting-users] postgres version for pgrouting?
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Sep 27 13:20:56 PDT 2013
On 9/27/2013 4:15 PM, Worth Lutz wrote:
> Thanks Steve,
> I thought that may be the case but wanted to be sure.
> I mucked up something on my dev machine trying to add 9.1 and was having
> great problems with "create extension pgrouting". I do not know what
> happened but I seem to have fixed it somehow.
> Is "stable" the best place to get pgRouting. It seems like "unstable" had
> "rc1".
I think Daniel will need to answer this. Once he rebuilds everything I
suspect that everyone will get initially sync'd to 2.0
After that, unstable will probably track the develop branch, which at
the moment is the same as master except for some documenation edits.
> What is the policy on what is in "stable" and what is in "unstable"?
I think stable tracks master and unstable tracks develop branches.
-Steve
> Thanks,
> Worth
> -----Original Message-----
> From: pgrouting-users-bounces at lists.osgeo.org
> [mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Stephen
> Woodbridge
> Sent: Friday, September 27, 2013 3:32 PM
> To: pgrouting-users at lists.osgeo.org
> Subject: Re: [pgrouting-users] postgres version for pgrouting?
> I believe Daniel plans to create other versions. I know he has been busy
> so I can't say when it will happen, but now that 2.0 is released I'm
> sure it will happen as soon as he has time to create them.
> -Steve
> On 9/27/2013 2:45 PM, Worth Lutz wrote:
>> I assume you mean if it is built from source.
>> I usually load from the ppa:georepublic/pgrouting
>> I try to avoid building stuff myself unless absolutely necessary.
>> So I guess my question is: must I build from source or will other
>> versions be available from the ppa?
>> Worth
>> *From:*pgrouting-users-bounces at lists.osgeo.org
>> [mailto:pgrouting-users-bounces at lists.osgeo.org] *On Behalf Of *James
>> David Smith
>> *Sent:* Friday, September 27, 2013 2:37 PM
>> *To:* pgRouting users mailing list
>> *Subject:* Re: [pgrouting-users] postgres version for pgrouting?
>> It'll work fine with 9.2.
>> On 27 Sep 2013 19:31, "Worth Lutz" <wal3 at mindspring.com
>> <mailto:wal3 at mindspring.com>> wrote:
>> I'm running on Ubuntu and getting pgRouting from the ppa.
>> Is Postgresql v.9.1 the only version supported?
>> I believe that my clients are using 9.2.
>> Worth Lutz
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org <mailto:Pgrouting-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>> No virus found in this message.
>> Checked by AVG - www.avg.com <http://www.avg.com>
>> Version: 2014.0.4142 / Virus Database: 3604/6700 - Release Date: 09/26/13
More information about the Pgrouting-users
