[pgrouting-users] Отн: Many to many routing and traffic assignment
Lyubomir Klyambarski
klqmba at yahoo.com
Mon Apr 7 08:06:16 PDT 2014
Hi! Thanks for the response.
I changed the from/to table a little - I created an table with 3 columns (from_vertice, to_vertice, traffic). And with this function I solve the problem:
CREATE OR REPLACE FUNCTION get_all_routes() RETURNS void AS
$BODY$
DECLARE
i record;
BEGIN
FOR i IN
select traffic.from_v, traffic.to_v, traffic.cars from traffic
LOOP
create table aux as select seq, id1 AS node, id2 AS edge, cost FROM pgr_dijkstra('
SELECT id,
source,
target,
cost
FROM osm',
i.from_v::integer, i.to_v::integer, false, false);
update osm
set trf=trf+i.cars
from aux
where id=aux.edge;
drop table aux;
RAISE NOTICE ' Running at % source id' ,i.from_v ;
end loop;
return;
END;
$BODY$
LANGUAGE plpgsql;
But it is a litle slower than I expected (~10 min for 28 pairs). Maybe if I use pgr_kdijkstra function I could speed up the process.
Best regards
На понеделник, 7 април 2014 г. 15:46, Stephen Woodbridge <woodbri at swoodbridge.com> написа:
On 4/7/2014 5:13 AM, Lyubomir Klyambarski wrote:
> Dear pgrouting users,
> I am begginer at using pgrouting and SQL as a whole, but this tool would
> be very useful for my projects. My task is to perform traffic assignment
> on the road network of Bulgaria. I use routable map prepared with
> Osm2po. My start/end points are defined according to the map nodes.
> Using the code from the example
> SELECT seq, id1 AS node, id2 AS edge, cost FROM pgr_dijkstra('
> SELECT id,
> source,
> target,
> cost
> FROM osm',
> 30, 60, false, false);
> how can I read my start/end points from another table and attach traffic
> value to the edges in new column?
> Thanks in advance.
Untested:
See the results:
select a.start, a.end, sum( (pgr_dijkstra(
'SELECT id, source, target, cost FROM osm',
a.start, a.end, false, false)).cost ) as cost
from routes a;
Update the cost column in routes:
update routes set cost=sum( (pgr_dijkstra(
from (select start, stop from routes) a
where routes.start=a.start and routes.end=a.end;
You might need to fiddle with the sql a little but this should give you
the idea.
-Steve
Pgrouting-users mailing list
Pgrouting-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20140407/cdf75837/attachment-0001.html>
More information about the Pgrouting-users
